Old 06-12-2018, 09:26 AM   #1
bryan.catano93
Drives: 2013 frs
Car jerking hard at WOT
i just installed my JDL turbo kit. car starts and drives. yesterday i received my first revision and went to take a WOT log but the car jerks very hard past 4k rpm. ( what i think its boost cut ). i went and checked all the lines and they seem okay to me. theres 2 logs attached, one is regular driving and the other one is my attempt to WOT. could someone please take a look at my logs and maybe try to help me out.
thanks
Mods: JDL turbo kit, base journal bearing turbo, recirc nameless catless overpipe/frontpipe combo, trd catback.
bryan.catano93 is offline   Reply With Quote
Old 06-12-2018, 09:37 AM   #2
bryan.catano93
Drives: 2013 frs
i cant upload the. csv file from the datalog. i can email them
Sent from my VTR-L09 using Tapatalk
Old 06-12-2018, 10:27 AM   #3
secho
secho's Avatar
Drives: GT86, forged and supercharged
Hi, upload it to the datazap.me and post the link.
Odesláno z mého SM-G950F pomocí Tapatalk
secho is offline   Reply With Quote
Old 06-12-2018, 11:09 AM   #4
bryan.catano93
Drives: 2013 frs
https://datazap.me/u/bryancatano93/l...og=0&data=7-19
Old 06-12-2018, 11:33 AM   #5
sid94
Drives: 2013 frs
Mine would do the same after 4K but my problem was that I was tuning for 10psi but had 20psi spring in the wastegate lol
sid94 is offline   Reply With Quote
Old 06-12-2018, 11:42 AM   #6
secho
secho's Avatar
Without seeing the tune it is hard to decide. It might be boost cut, load limits, incorrecty set load axis and calculation (seems it fuelcuts above 2g/s of load). But at krást, you should fix fueling first. Fuel trims Are highly out of reasonable limits. Also flkc goes almost -5degs. Not So good.
Old 06-12-2018, 11:47 AM   #7
bryan.catano93
Drives: 2013 frs
anywhere i should start checking? would thr fuel trims be out of spec due go boost leak?
Old 06-12-2018, 12:31 PM   #8
bryan.catano93
Drives: 2013 frs
i bought the kit used and saw that it has a recirc kit option from the wastegate. i didnt mention that to my tuner. would that have ajlnything to do with my issue?
Old 06-12-2018, 01:40 PM   #9
secho
secho's Avatar
It might be an issue. But you have to consult with your tuner. Do you have the tuning file in decoded/open form? Can you read it in the ProEcu?
Old 06-12-2018, 05:12 PM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
I would say that looks like boost cut, probably on an early revision tune to make sure everything is OK.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-12-2018, 05:35 PM   #11
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
You have the JDL 3bar map sensor, right?
Old 06-12-2018, 05:38 PM   #12
bryan.catano93
Drives: 2013 frs
im not sure if i do. yeah i talked to my tuner, hes out of town for the week tho so i kinda wanna do some. digging on my own
Old 06-12-2018, 05:39 PM   #13
bryan.catano93
Drives: 2013 frs
4 bar map from jdl yes.
Old 06-12-2018, 05:40 PM   #14
bryan.catano93
Drives: 2013 frs
yeah its the first revision after the basemap. what could be causing the boost cut?
Sudden Power Loss / Hesitation and jerking under WOT Jesse36m3 Forced Induction 6 05-14-2018 09:59 PM
Engine bogging / stumble / hesitation / jerking during accelaration ard 2.5k - 3k RPM mo420 Issues | Warranty | Recalls / TSB 24 07-29-2017 07:35 PM
CEL p0456 code, jerking when braking RedNWhite Issues | Warranty | Recalls / TSB 7 06-03-2016 06:35 PM
M/T and idling over speed bumps - jerking mstoochn Issues | Warranty | Recalls / TSB 7 04-29-2015 04:45 PM
Was I being hard on my car? Fr-s13 Scion FR-S / Toyota 86 GT86 General Forum 49 07-04-2013 09:54 PM
