#562 |
86 Challenge
Drives: 2017 BRZ
I installed the setup per original write up (I think) and I’m noticing zero difference and looking at what I’ve done, it makes no sense either. It’s essentially running in parallel to the heater core return line?
Somebody correct me if I’m understanding this wrong. EDIT: Nevermind, oil this oil cooler makes such a small difference you won’t be able to see it without data logging. Source, this thread: http://www.ft86club.com/forums/showthread.php?t=93127 Also, Vibrant Performance 11417 works well for the M14x1.5 to hose barb fitting. Last edited by mkodama; 12-27-2017 at 08:19 PM. |
#563 |
Drives: 2017 Subaru BRZ Limited Performance
Options for the barb fitting without using adapters:
http://www.jegs.com/i/Vibrant-Perfor...11417/10002/-1 http://www.jegs.com/i/JEGS-Performan...00478/10002/-1 |
| The Following User Says Thank You to nick.cfrancis For This Useful Post: | monkeybike (02-13-2018) |
#564 |
Drives: 2013 Toyota 86
What is the consensus on throttle body routing vs parallel to the heater core routing?
Guessing I dont need the adapter fitting if the throttle body routing is used. Throttle body routing looks a lot simpler and looking at the link on page 40 it works well. |
#565 |
Looking through the pictures on this thread, it looks like there are two ways that the Forester water pipe is being positioned. Just wondering which one is the correct way?
Fitment A or Fitment B? |
#566 | |
Drives: Late 2014 Subaru BRZ
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe |
#567 |
Fitment A is how mine looks.
2014 Subaru BRZ
#568 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
#569 |
Drives: Q5 + BRZ + M796
If anyone doesn’t want their old coolant pipe then hit me up. I’m doing a project and could use the pipe. It saves me a trip to the junk yard.
#570 |
So what was this project?
#571 |
Old news. I got the pipes from a pick n pull. Check my build. I will be routing my supercharger coolant lines different than what the kit calls for.
| The Following User Says Thank You to Irace86.2.0 For This Useful Post: | weederr33 (06-06-2018) |
#572 |
Drives: 2017 Toyota 86
So, is the Ned oil cooler kit the same thing..As the Forester XT part # 21317AA070 and #21311AA170?
#573 |
Yes. But the NED is only those two parts, plus some hosing for the throttle body route.
#574 |
Drives: BRZ my18
Ho guys, I would like to mount this system in my car and would like to know if this fitting is correct! it's made of steel, and I think it's better than aluminum. confirm?
https://www.ebay.co.uk/itm/273563943419 Thank you. |
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
