#547 |
Drives: WRX
If anyone is interested im selling almost everything in this kit, just missing on piece.
http://www.ft86club.com/forums/showthread.php?t=107896 |
#548 |
Drives: brz
PM'd , let me know !
#549 |
BoostedBRZ
Drives: Turbo BRZ
does anybody have the height of the forester oil cooler? Basically the height for part number 21311AA170
#550 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#551 |
Drives: BRZ + Ducati M796
#552 |
Drives: BRZ Club blanc perle
As water going up faster than oil, it will rise the oil temp quicker. A radiator will low the temperature, that's why you then needs a thermostat plate.
Collecteur et frontpipe Supersprint full décat - Catback Remus Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons |
#553 |
Drives: bmw
have some data and comparisons for this kit when pushed hard. go with the throttle body routing
https://www.pointmeby.com/2016/09/18...z-frs-gt86-86/
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#554 |
Drives: 2013 Black BRZ Limited
Has anyone run into coolant leaks with this setup? I burped my system with a spill free funnel and ran the car for 10-15 min until the air bubbles slowed way down.
The morning after the install I found a nice antifreeze puddle on the street under my BRZ. It appears to be a small leak. No issues from the front pipe or connections off the oil cooler itself. Then I found this at the bottom. ![]() Luckily the nipple didn't seem to be exhibiting any issues. I was worried I'd have to deal with that... after loctiting it in. ![]() Following the trail of dried coolant further, it looks like the smaller pipe and hose by the firewall is the source of the leak. ![]() I'm struggling right now to get that little hose clamp back off but will end up replacing it with a standard one once I do. |
#555 |
Drives: 2013 Toyota GT86
Hey guys, while surfing the interwebs, looking for cheaper subaru parts stores I found this one. For people living in the southeast part of the US this would be a great place. Don't know if shipping will be more for the west coast, I doubt it, but the price shipped came to $268.54 shipped. Hope this helps.
http://www.subarupartssuperstore.com Last edited by TunaNoCrust1984; 05-10-2017 at 03:48 PM. |
#556 | |
BoostedBRZ
Drives: Turbo BRZ
| The Following User Says Thank You to pgranberg11 For This Useful Post: | sroby (01-28-2019) |
#557 |
Drives: wrb brz
Just about to try out the throttle version install and wondering if there is any importance to the way the hoses hook up from the cooler to the throttle body (how to tell which goes to the inlet and which to the outlet) also what size hoses to use that fits the barb on the throttle nipple, read threw the thread one guy said 3/8" and others say 1/2"
thanks! |
#558 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Hey everyone, I've got a fairly stupid question I'd like to ask!
I'm planning on installing the Forest XT oem oil cooler/ regulator but wanted to know if I could simply reuse my engine coolant, when I drain the system, instead of buying several containers of it. Being that the car is roughly 6mo old, I didn't see any reason it wouldn't work as long as I use a clean pan with no contaminants. Thoughts?
#559 | |
I did it twice using empty distilled water jar. You can connect hose from overflow tank to the tip of drain nipple then collect coolant straight to water jar. When I refill it, I filtered it just in case. 나의 SM-N950U 의 Tapatalk에서 보냄 |
| The Following User Says Thank You to nunonuna For This Useful Post: | weederr33 (10-30-2017) |
#560 |
What did you use to filter the coolant?
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
