Old 11-02-2017, 03:50 PM   #561
nunonuna
nunonuna's Avatar
Originally Posted by weederr33 View Post
What did you use to filter the coolant?
I used an empty tea bag / tea pouch with strings(non paper base). I wrapped it over the mouth of jar then pour coolant into fill funnel when refill. I've seen people using coffee filter & shop towel as well.
nunonuna is offline   Reply With Quote
Old 12-25-2017, 02:41 AM   #562
mkodama
86 Challenge
Drives: 2017 BRZ
I installed the setup per original write up (I think) and I’m noticing zero difference and looking at what I’ve done, it makes no sense either. It’s essentially running in parallel to the heater core return line?
Somebody correct me if I’m understanding this wrong.
EDIT: Nevermind, oil this oil cooler makes such a small difference you won’t be able to see it without data logging. Source, this thread: http://www.ft86club.com/forums/showthread.php?t=93127
Also, Vibrant Performance 11417 works well for the M14x1.5 to hose barb fitting.
mkodama is offline   Reply With Quote
Old 02-13-2018, 09:04 PM   #563
nick.cfrancis
Drives: 2017 Subaru BRZ Limited Performance
Options for the barb fitting without using adapters:
http://www.jegs.com/i/Vibrant-Perfor...11417/10002/-1
http://www.jegs.com/i/JEGS-Performan...00478/10002/-1
nick.cfrancis is offline   Reply With Quote
Old 02-22-2018, 07:31 PM   #564
Harey
Drives: 2013 Toyota 86
What is the consensus on throttle body routing vs parallel to the heater core routing?
Guessing I dont need the adapter fitting if the throttle body routing is used. Throttle body routing looks a lot simpler and looking at the link on page 40 it works well.
Harey is offline   Reply With Quote
Old 03-27-2018, 12:22 PM   #565
nick.cfrancis
Looking through the pictures on this thread, it looks like there are two ways that the Forester water pipe is being positioned. Just wondering which one is the correct way?
Fitment A or Fitment B?
Old 04-03-2018, 11:58 AM   #566
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Originally Posted by nick.cfrancis View Post
I'm using the first one with the washer and I recommend using a washer or it will leak as this was not my first or I used and had a leak and replace it. As far as the oil cooler goes I'm using the same exact oil cooler / heat exchanger. I only use the car around town so it works perfectly but I'm not sure how would hold up on the track. Plus side about this heat exchanger oil cooler is the oil temperatures does rise much quicker if you're running a turbo.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-03-2018, 12:00 PM   #567
GsxrMe
GsxrMe's Avatar
Fitment A is how mine looks.
2014 Subaru BRZ
Old 04-06-2018, 07:13 PM   #568
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
It appears both offer washers. Was gonna pick up one of these two.
MS, CSCS, TSAC-F, CPT
Old 04-27-2018, 10:31 PM   #569
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
If anyone doesn’t want their old coolant pipe then hit me up. I’m doing a project and could use the pipe. It saves me a trip to the junk yard.
Old 06-06-2018, 02:44 PM   #570
weederr33
weederr33's Avatar
So what was this project?
Old 06-06-2018, 04:03 PM   #571
Irace86.2.0
Old news. I got the pipes from a pick n pull. Check my build. I will be routing my supercharger coolant lines different than what the kit calls for.
Old 09-10-2019, 03:45 PM   #572
Contender
Drives: 2017 Toyota 86
So, is the Ned oil cooler kit the same thing..As the Forester XT part # 21317AA070 and #21311AA170?
Contender is offline   Reply With Quote
Old 09-10-2019, 11:49 PM   #573
weederr33
weederr33's Avatar
Yes. But the NED is only those two parts, plus some hosing for the throttle body route.
Old 01-30-2020, 08:54 AM   #574
Mattia M.
Mattia M.'s Avatar
Drives: BRZ my18
Ho guys, I would like to mount this system in my car and would like to know if this fitting is correct! it's made of steel, and I think it's better than aluminum. confirm?
https://www.ebay.co.uk/itm/273563943419
Thank you.
Mattia M. is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
