#43 | |
/scion
Drives: '13 86 M/T
FIFY
"Practice makes better. Only Senna is perfect." - CSG Mike
| The Following User Says Thank You to LOLS2K For This Useful Post: | Icecreamtruk (05-04-2018) |
#44 | |
Drives: 2017 BRZ PP WR Blue
I got -1.3 on both sides from just replacing the bolt (no swapping anything around). Works OK after several track days, given the fact that the rest of the car is stock (slow, low traction). If you want more, you have to use adjustment plates. |
#45 |
Drives: 2017 DGM BRZ PP
I got -2.3 on both sides by using two pairs of camber bolts. SPC 81305 and 81280. So it can be done without plates.
#46 |
Drives: '13 FRS - STX
Code reader is a good idea for any OBD2 car hitting the track.
Should be able to get -2 or more with two camber bolts, well worth trying to get imho. |
#47 | |
My friend, who owns the local alignment shop that caters to SCCA, NASA, and FARA racers, advised me not to double up on eccentrics. If I remember correctly, the instructions that came with the bolts from Whiteline said the same thing. There are lots of ways the YOU might choose to get more than -2.0 without plates, but I wouldn't... |
#48 | |
Drives: 2017 BRZ
#49 |
#50 |
Drives: 2017 BRZ
I was attempting to point out that you could get ~-3° (assuming tire/wheel clearance) on just bolts using only one eccentric. I believe the usual answer is to get the bottom eccentric, and put the bottom bolt in the top.
YMMV, etc. The camber makes a huge difference in tire wear though, not to mention front grip.
#51 | |
SSC konis have larger bolt holes than OE for extra camber. |
| The Following User Says Thank You to strat61caster For This Useful Post: | cjd (05-05-2018) |
#52 |
Drives: 2017 BRZ
Right you are, I always forget that.
#53 | |
![]() Quote:
#54 | |
#55 |
This is really the first I've heard of it not being recommended, though. I looked through posts on the forum and didn't find anything against it, really. As I understood it the risks are pretty minimal. Are there any reports of failures or frequent slippage running two pairs of eccentric bolts? I understand why a shop would recommend against it, but is it a risk in reality?
#56 | |
| Any news of Performance Pack for 2018? | dowroa | BRZ First-Gen (2012+) — General Topics | 10 | 10-26-2017 01:08 PM |
| 2017 performance pack Sachs | Last Lemming Alive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 06-17-2017 06:28 PM |
| Performance Pack Brake Dust? | Opie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-03-2017 11:47 AM |
| Track day toolbox essentials | kurbkilla | Tracking / Autocross / HPDE / Drifting | 7 | 12-02-2013 03:32 PM |
| GT-86 optional performance-pack | Ziptuning | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 08-29-2012 03:00 AM |
