Old 06-16-2017, 11:59 PM   #1
Last Lemming Alive
Drives: WRB 2017 BRZ Limited w/ PP
2017 performance pack Sachs
What is the current thinking as to how much of a drop on the 2017 Sachs dampers can take and still give good body control and decent life expectancy?
Last Lemming Alive is offline   Reply With Quote
Old 06-17-2017, 12:07 AM   #2
swarb
What is your definition of decent life expectancy?
Old 06-17-2017, 07:39 AM   #3
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
To add to @swarb's question above define the kind of life you mean? Tight and twisty with metre deep potholes every 15 seconds or a billiard table smooth freeway with a 2mm ripple strip every 1/2 hour.
How long is a piece of string?
Old 06-17-2017, 07:52 AM   #4
jmark
Drives: '97 NSX-T, '18 Type R
RCE says the RCE Yellow springs work well with the PP Sachs shocks. A couple of members are doing this swap. Then when the shocks wear out replace with Bilstein B6.
jmark is offline   Reply With Quote
Old 06-17-2017, 08:58 AM   #5
Gforce
Drives: 2013 Subaru BRZ
The more important question to ask is whether the 2017 shocks are suitable for the spring rate you will need to effect the drop you have in mind.
Assuming you don't mess around with bump stops that are too short the dampers don't care where they operate within their normal stroke. Shocks are usually pretty tolerant of operating in different ranges of stroke.
You have five inches of ground clearance. Dropping by more than 1.5 in would be ill advised. This would not affect the shocks.
Increasing the spring rate may well take your suspension outside the designed operating range of the Sachs from a spring damping perspective.
Gforce is offline   Reply With Quote
Old 06-17-2017, 11:05 AM   #6
Cole
Not a troll
Cole's Avatar
Assuming that the dampers aren't still over damped for stock spring rates.
Old 06-17-2017, 06:28 PM   #7
Gforce
Correct. Which begs the question of how far off the factory choice of spring rate to damper rate is.
In my judgment based on my setup I would say the 2017 spring rates are very well matched to the Bilstein B6 have. I would be very surprised if Subaru selected stiffer damping rates for the Sachs package than the Bilstein B6.
If I am correct then one would be foolish to fit higher rate springs to the Sachs damper set.
Which is my point. The op is asking the wrong question.
Enkei TS10 on 2017 Brz with Performance Pack tfp Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 06-19-2019 10:18 AM
SACHS Performance coilovers Shark_Bait88 Brakes, Suspension, Chassis 2 04-22-2017 09:33 PM
2017 with Perfromance Pack - What wheels? prattusa Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-11-2017 02:32 PM
SACHS Performance Coilovers (Now installed with review!) Shark_Bait88 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 04-25-2016 10:46 AM
