#29 | |
Drives: 2013 WRB BRZ 6MT
Brake pads: Winmax W5 or equivalent brake pad is where I would start. I personally find them a bit overkill for my application but I only have 30 minute sessions. Someone mentioned the GT brake ducts, get those if you find you are managing to get pad fade before you step up to something more aggressive. Fluid: RBF600 is the minimum I'd consider for a track day. It's cheap and it will hold up fine for the track day but you'll have to perform a partial bleed after every event to restore a solid pedal which gets old fast. On the other end of the spectrum, the high end fluids will run $90/litre but you flush once at the beginning of the season and you're good until next year. I ran RBF600 my first 2 years doing track and switch to Castrol SRF React last year and was very impressed with it and I still daily drive on the original flush I did last year. Hoses: As others have said, no need to waste money here. Engine oil: The manual recommends using a 5W30 for extreme use. I run 5W30 during the summer and switch to 0W20 in the winter. Oil cooler: Considering your use, I would definitely invest in one. Tires: Considering the discounts available to you, your options are somewhat limited compared to others. Purely anecdotal but I'm on Hankook RS3 and a guy with a Nissan 350Z on RE71r passed me like I was standing still early in the session but I caught up to him and overtook him about 5 laps later after he overheated his tires. If you're chasing lap times, RE71r is unbeatable in it's class but if you want to build consistency, a more consistent tire might be better. Of course, running a tire like this will also teach you more about tire heat management which is an important skill in itself and is why I'm planning to run a tire like this when I finish off my RS3s which have helped me build some consistency. Wheels: At this stage, sizing depends on what you plan to do with the car. If you just want to go on track and keep costs down, I think going for a 17x7 with 215/45 is a good idea. If you are going to do 86cup or SSC then a 17x8 with 225/45 is good. If you want to go as fast as possible or go STX, maybe get a 17x9 with 245/40 now so you don't need to get one later. Note that you can safely fit a 245/40 on a 17x8 wheel with a bit of pinch so you can still run that size of wheel and be competitive in STX although you may lose a bit of response and feel from the tire compared to running it on a 17x9. A note about the PP Brembos: Most RPF1s won't fit over the Brembos, I think the 17x8 +45 is the only one that will IIRC. That said, they are such a popular wheel that I personally don't care to run them when there are compelling alternatives in the same weight/price category with better brake clearance like Konig Hypergram, 949 6UL, Apex Arc-8 and 720form GTF1 to name a few off the top of my head. Suspension: As others have said, start with some camber bolts and get as much negative camber up front as you can but be aware that it's not going to be enough for even tire wear. Most people report needing at least -3f/-2r for even tire wear which isn't possible with bolts alone. You either need camber plates or lowering springs to reach -3 in the front. Most people get springs when the wheel gap starts killing them a little inside lol. Rear lower control arms will be required to adjust rear camber too. I'd vote to just get a set of rear control arms now along with the bolts so you can make those adjustments now and not have to worry about it later. I've used the SPC arms just fine for the last 3 years. Safety: Go for it, additional safety is never a bad idea. |
#30 |
Thanks everyone so far for the really useful information! My first event is at Lime Rock on the 23rd; I plan to get track pads, Castrol SRF fluid, oil change to 5W30, front camber bolts and alignment, and go from there. This event shouldn't have as much track time so I'm hoping it'll hold together nicely until I need additional cooling, suspension tweaks, etc.
Just got a couple action cams too so I'll be recording my slow slow laps and see where I can improve later
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
| The Following User Says Thank You to Turbowned For This Useful Post: | Racecomp Engineering (04-09-2018) |
#31 |
@CSG David and @CSG Mike,
I'd like to go with a set of Winmax pads, but given that this is the first set of dedicated track pads I've ever bought, I'm not sure which ones to go with. The W4/5 seem good but appear to cause more rotor wear, whereas the W6 seem like they operate in too high a temperature range for my needs. The W7 seems like the best but are also the most expensive. Any chance you could point me in the right direction? I can't imagine I'd need anything too crazy considering stock power output and I'm not operating the car in a full competition setting or doing endurance racing or anything like that.
#32 |
Drives: 2014 Silver BRZ Track Car
Great responses for you but there is one topic that I would like to address for you.
Although these engines were designed to 0w20 I would recommend to stay as far of it as you can if you plan to be anywhere near a race track. My 2014 BRZ is a caged fully prepped time attack car and I personally use Liquid Molly 10W60 since my car gets 0 miles in the street. It is not street legal. I add Liquid Molly MoS2 engine treatment religiously at every oil change. I have an engine oil pressure gauge and this oil is the only one that when it is really hot keeps it over 10 psi of engine oil pressure at idle. Basics are basics not matter what. I could not care anything at all about the 0w20 mindset of oil usage or anything in between as I know very well how bearings wash out. I have tested 5W30 and 0W40 and they blow for hot oil pressure at idle. I have thousands and thousand of really hard track miles in this motor and with this oil and additive, my engine is a happy one so... to each its own. I do have a JR oil cooler and a KOYO radiator but I run NA with e85 tune and catless header with free flowing exhaust. I hope this helps you. For the rest of the stuff you already have great advice. I strongly suggest adjustable camber more than the offset bolts and also save yourself time and just bite the bullet and use Castrol SRF brake fluid which is simply the best. Best lock to you! |
#33 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Turbowned (04-20-2018) |
#34 | |
#35 |
Drives: DE5 Integra Type S
This may have already been mentioned but Jackson Racing just released their new oil cooler and dual cooling rad and they now fit 2017+ as well. Check out their site.
"Precision without speed is empty, speed without precision, chaos."
#36 |
W5 it is! Placed my order; thank you! Thanks to those who suggested the GT3 brake ducts; found them dirt cheap on Amazon... hopefully they're the right ones.
| The Following User Says Thank You to Turbowned For This Useful Post: | CSG Mike (04-22-2018) |
#37 |
#38 |
Drives: 2015 Subaru BRZ Limited DGM
GT3 brake ducts?
#39 |
My 2cents with my limited experience.
Contact CSG_David of Counterspace Garage for recommendations based on your use case. Also contact your local 86Cup group and join Brake pads: Winmax W5 minimum. Brake fluid: Project Mu G-Four 335 Fluid Hoses: OE brake lines OK Engine oil: 0w-20 Motul 300V Oil cooler: Required. Jackson Racing Oil Cooler Tires: 225/45/17 GT Radial SX2. Not the stickiest tire, but gives consistent performance, lasts long and great learning tire. Wheels: The stock PP wheels are good. Enkei RPF1 has weird fitment issues on the PP. I use OZ Ultraleggera 17x8 and has good clearance. Suspension: Camber bolts ok. Keep the stock sway bars. No need for spacers unless needed for brake/wheel clearance Safety: HANS
| The Following User Says Thank You to mixxxx For This Useful Post: | TofuJoe (05-05-2018) |
#40 |
Ok so this i probably another post for another time but, I installed the SPC rear control arms and front camber bolts. The rear arms allow for some ridiculous amt. of adjustment; roughly 5 degrees. The fromt camber bolts with the bottom OEM bolt swapped with the top bolt per suggestions nets a whopping 1.5 on the left and 1.1 on the right. Am I doing something wrong? I can theoretically get more front camber with two sets of the camber bolts because the physical diameter of the bolts are smaller, yes?
#41 |
Drives: 13 BRZ, 97 e36 M3 Rides: '07 600RR
Might also be a good idea to bring a spare ignition coil and engine code reader. I've had a CEL on track and ended up being a P351. Cyl 1 is the likely cultprit and can be done between sessions.
| The Following User Says Thank You to hyper4mance For This Useful Post: | strat61caster (05-04-2018) |
#42 |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
| Any news of Performance Pack for 2018? | dowroa | BRZ First-Gen (2012+) — General Topics | 10 | 10-26-2017 01:08 PM |
| 2017 performance pack Sachs | Last Lemming Alive | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 06-17-2017 06:28 PM |
| Performance Pack Brake Dust? | Opie | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 03-03-2017 11:47 AM |
| Track day toolbox essentials | kurbkilla | Tracking / Autocross / HPDE / Drifting | 7 | 12-02-2013 03:32 PM |
| GT-86 optional performance-pack | Ziptuning | Scion FR-S / Toyota 86 GT86 General Forum | 24 | 08-29-2012 03:00 AM |
