Old 04-09-2018, 02:15 PM   #15
Racecomp Engineering
No one's gonna ask him why he's running 18 kg/mm springs?
- Andrew
strat61caster (04-09-2018), wparsons (04-10-2018)
Old 04-09-2018, 02:17 PM   #16
Brzxton
Drives: 2015 Subaru Brz
Originally Posted by 8RZ View Post
Damn, talk about rake lol.
Yea haha i raised up the front to match cause it looked terrible
Brzxton is offline   Reply With Quote
Old 04-09-2018, 02:18 PM   #17
Brzxton
- Andrew
The person i had bought the coils from put them on im not sure why he chose to though.
Old 04-09-2018, 02:26 PM   #18
Brzxton
Originally Posted by wparsons View Post
I meant actually check the springs you have front/rear to see which rates are on which end and how long the springs are front/rear.
If you have the springs on the wrong end and the front springs are longer then this is explained really simply.
I bought the coilovers used from someone but he had the swifts on the rear when i got them. The fronts are the 8k springs that come with the coils and rear is 18k which. As for why he chose to get the swifts i have no idea.
Old 04-09-2018, 02:35 PM   #19
DAEMANO
Time Traveller
Call PBM in San Diego, they'll be able to tell you exactly what's wrong and probably fix it on the spot if you can make it down there. They have a great facility and helpful staff.
220 Engel St.
Escondido, CA 92029
ph. 858-566-6969
fax. 858-566-6996
maxusa@partsshopmax.com
Old 04-09-2018, 02:36 PM   #20
DAEMANO
Time Traveller
- Andrew
I assumed he was towing a 5th wheel or something.
Old 04-09-2018, 02:57 PM   #21
Student Driver
Drives: 2013 Scion FRS Series 10
I have PBM Coils and never had that issue. I recommend buying new short springs from PBM. IIRC they are like $100 for a pair and you can get whatever spring rates you want, up to 20k. I couldnt max out my rears because it was too low if I did, so I bet the spring is the wrong size... also if the previous owner didnt have the struts on those tuned for the stiffer springs the struts could be blown, not saying they are but when i talked to their customer service they were telling me stiffer springs without the dampening spec'd correctly could create issues. also if you max out the rear with what looks to be all stock arms, you are going to have some pretty shitty toe. i found that out the hard way. rlca's, toe arms, and traction arms are highly recommended when lowering your car that much. PBM sells all of that stuff too, and their rlca's will drop your car an ext 40mm i think. good luck!
here is a link to PBM's frs parts page https://store.partsshopmax.com/shop/FRSBRZ/
Student Driver is offline   Reply With Quote
Old 04-09-2018, 03:51 PM   #22
norcalpb
norcalpb's Avatar
- Andrew
I thought it was a typo. He has stiffer springs than my buddy’s lifted 4Runner if that’s the case.
Old 04-09-2018, 03:55 PM   #23
Brzxton
Haha yea they are indeed 18k swifts. Not sure why the person i bought them from out them on.
Old 04-09-2018, 04:02 PM   #24
norcalpb
norcalpb's Avatar
That’s probably what your issue is then. I have 4.5k springs in the rear and they compress nearly all the way up into its wheel well slot.
Old 04-09-2018, 04:16 PM   #25
Brzxton
Maybe but the guy i bought them from said when he put the springs on it didnt change his ride height. Idk just gonna end up getting some stance lca’s
Old 04-09-2018, 04:29 PM   #26
OND
OND's Avatar
Drives: 2023 BRZ
Stop being so naive. The guy who sold you the coils is a lying idiot who knows jack shit about suspension setup.
Many people already told you what the problem is. Why even post here if you are just going to ignore their advice?
OND is offline   Reply With Quote
The Following 2 Users Say Thank You to OND For This Useful Post:
Cole (04-09-2018), wparsons (04-10-2018)
Old 04-09-2018, 04:37 PM   #27
Perhaps he meant they didn't change his ride height as in when he set the car down on the ground after installing them they didn't compress much at all because they are so stiff.
Those spring rates aren't the best choice for your car IMO. My guess is the guy who sold you those coilovers was trying to be a drifter, but didn't do a very good job of building his suspension. That's putting it nicely.
- Andrew
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
Brzxton (04-09-2018), strat61caster (04-09-2018), wparsons (04-10-2018)
Old 04-09-2018, 04:39 PM   #28
Brzxton
I havent and idont think he is lying because his car was slammed on them. And people have given me multiple reasons on what they think the issue is. I havent ignored anyones advice. No need to get heated.
Front and Rear Camber kit /w Coilovers slow n FuRiouS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-07-2016 06:59 PM
Can't Get Rear Coilovers Off? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 07-28-2015 01:59 PM
protecting the extended top nut/stud on rear coilovers DuMa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-07-2015 11:21 AM
Noise in the Rear with ST Coilovers DemonRawr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-01-2015 10:21 PM
BC coilovers - Help w/ removing rear collar(s) ang31ito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-11-2014 11:57 AM
