Old 04-07-2018, 06:37 PM   #1
Brzxton
Drives: 2015 Subaru Brz
Pbm coilovers not low in rear?
So i bought some used pbm coilovers since ive heard good things about pbm and theybare local. When i installed them, the front was exactly how i wanted it. But when i put on the rears, they are higher than my lowering springs. There is a 4 finger wheel gap. Am i doing something wrong or will i need lca’s to get lower. Btw the rears are maxed out.
Brzxton is offline   Reply With Quote
Old 04-07-2018, 09:13 PM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Pic of the rear strut please.
Old 04-07-2018, 11:19 PM   #3
humfrz
Maybe you put them on upside down and/or are adjusting them the wrong direction ...... sorry, I just remembered I slept through my med taking time ......
humfrz
Old 04-08-2018, 02:41 AM   #4
Brzxton
humfrz
Shit i put them in horizontally
The Following User Says Thank You to Brzxton For This Useful Post:
humfrz (04-08-2018)
Old 04-08-2018, 03:53 PM   #5
Brzxton
Heres a pic of the coilover
Old 04-08-2018, 04:48 PM   #6
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Can you unlock all the lock rings and screw the body of the shock into the lower half? Basically, take off the shock. Undo all the lock rings. Make sure the piston shaft is all the way out of the shock. Reset spring tension with the upper two lock rings. Then reset ride height with the lower lock ring by raising/lowering the cylinder into the lower shock body. Then locking the lower ring when ride height is set.
Also, are the front and rear springs on the correct shock? Not front mixed with rears?
JimmyMac is offline   Reply With Quote
Old 04-08-2018, 04:59 PM   #7
Brzxton
Its as far down as it goes because i cant screw the damper any farther because it hits the bottom of the piece that bolts to the lca. And im pretty sure the springs are on the correct ones.
Old 04-08-2018, 06:01 PM   #8
norcalpb
norcalpb's Avatar
Have you driven on the coils to allow the springs to settle yet?
Old 04-08-2018, 06:57 PM   #9
Brzxton
Yessir
Old 04-08-2018, 10:57 PM   #10
wparsons
wparsons's Avatar
I'd check the spring rates/lengths if the adjustment really is bottomed out as low as it'll go.
flickr
Old 04-08-2018, 11:58 PM   #11
Brzxton
The rears are 18k but idk the length probably 5 or 6”
Old 04-09-2018, 12:44 PM   #12
wparsons
wparsons's Avatar
I meant actually check the springs you have front/rear to see which rates are on which end and how long the springs are front/rear.
If you have the springs on the wrong end and the front springs are longer then this is explained really simply.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Cole (04-09-2018), JazzleSAURUS (04-09-2018)
Old 04-09-2018, 01:59 PM   #13
Cole
Not a troll
Cole's Avatar
Looks like swift springs, which AFAIK are custom ordered for these.
I'd be willing to bet OP ordered the wrong length of spring
The Following User Says Thank You to Cole For This Useful Post:
wparsons (04-10-2018)
Old 04-09-2018, 02:06 PM   #14
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Damn, talk about rake lol.
Current DD: M235i
8RZ is offline   Reply With Quote
Front and Rear Camber kit /w Coilovers slow n FuRiouS Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-07-2016 06:59 PM
Can't Get Rear Coilovers Off? 636 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 07-28-2015 01:59 PM
protecting the extended top nut/stud on rear coilovers DuMa Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 05-07-2015 11:21 AM
Noise in the Rear with ST Coilovers DemonRawr Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-01-2015 10:21 PM
BC coilovers - Help w/ removing rear collar(s) ang31ito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 06-11-2014 11:57 AM
