#15 | |
(maybe I shouldn't have cut back on that expensive med ... ??) humfrz |
#16 | |
/dev/null
Drives: Uphill
| The Following 2 Users Say Thank You to Sarlacc For This Useful Post: | humfrz (01-09-2018), Ultramaroon (01-09-2018) |
#17 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Sarlacc (01-09-2018), Ultramaroon (01-09-2018) |
#18 |
Much funnier when they have to be explained.
I'm guilty of being too terse. Inaccurate, actually. If the issue is due to "works as designed," then running it below a quarter tank should do the trick. I haven't personally seen it but the topic has been discussed here a few times.
#19 |
Welp, maybe we should just go back to having a reserve part of the gas tank, controlled by a simple little lever, pretty hard to mess that up ......
![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Sarlacc (01-09-2018) |
#20 |
Drives: 2015 Subaru BRZ series.blue
I ended up removing the unit, making sure the float arm went in properly and did not get hung up on the hose inside the tank. . The actual inside of the tank is pretty shallow, so there is not a lot of space for the arm to hang down. Once you push the assembly down and compress it, you don't want to twist it more then necessary. It seems to be working now.
#21 |
You need to move to Dallas to fix that problem. You are not allowed to use them anywhere in Dallas county!
#22 | |
![]() ![]() humfrz |
| What is the secret to lining up the blue marks on the fuel pump assembly | amanzoli | Engine, Exhaust, Transmission | 1 | 01-04-2018 02:46 AM |
| Fuel pump assembly: Fuel pressure regulator popping out | sfruski | Engine, Exhaust, Transmission | 2 | 09-15-2017 10:39 PM |
| OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu | ndreim | Engine, Exhaust, Bolt-Ons | 5 | 11-24-2016 12:36 AM |
| FS SOCAL: Perrin Oil Cooler, Koyo Radiator, ECU, Stock Fuel Pump Assembly | John Rambo | Engine, Exhaust, Bolt-Ons | 8 | 04-26-2016 02:57 PM |
| Fuel pump hanger assembly | slicktop | Want-To-Buy Requests | 1 | 12-09-2014 04:23 AM |
