Old 03-25-2016, 08:16 PM   #1
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Cool FS SOCAL: Perrin Oil Cooler, Koyo Radiator, ECU, Stock Fuel Pump Assembly
Koyo Radiator Pictures:
-Was on the car for roughly 12k miles
-No leaks or any problems, professionally installed and removed
-KOYO RADIATOR Asking $215, price negotiable
Perrin Oil Cooler SOLD Pictures:
-Pardon the messy box, it's dry and I promise it won't ship with oil leaking out of the box.
-Was also on the car for roughly 12k miles
-Professionally Installed and Removed
-Pictured is the cooler on a custom mount, I also have the Perrin supplied mounts that were never used.
-The hose cover has a slight cut on it from rubbing on the crash beam. Rest assured the cut is only on the outer covering of the hoses and not on the oil lines themselves, the lines do not leak, and this does not affect the performance or durability of the kit.
-No issues or problems with this cooler! Comes with cooler, hoses, thermostat, and mount
-PERRIN OIL COOLER SOLD
Stock 2015 ECU out of a crashed FRS:
-This ECU is in good shape. The cover is cracked but you can use your old cover or just leave it, the board inside is mint.
-It works perfect, I didn't end up using it because it's for a 2015 FRS and it isn't compatible with 2013 or early 2014 ECU's.
-PM me if you have questions on compatibility.
-2015 ECU Asking $120
Stock Fuel Pump Assembly, out of a crashed FRS:
-I bought this awhile ago when I wasn't sure if I needed a new assembly because the float on mine came off. I used a zip tie on my own stock fuel pump and I never put this one in my car, it's been sitting in the garage for a while.
-It came out of an FRS with 30k miles IIRC.
-It's a complete, stock fuel pump assembly. Pretty self explanatory
-FUEL PUMP ASSEMBLY Asking $85
Located in SoCal, prefer not to but will ship at buyers expense. PM me with Offers!
More to come soon, including FBM Turbo Kit and aftermarket exhaust - Check back later
John Rambo is offline   Reply With Quote
Old 03-26-2016, 04:30 PM   #2
John Rambo
John Rambo's Avatar
UPDATE: Perrin Oil Cooler SOLD
Old 03-26-2016, 08:36 PM   #3
tumbla.jr
taicho
tumbla.jr's Avatar
Drives: The rEd Fr-S
You have a pm sir
tumbla.jr is offline   Reply With Quote
Old 03-27-2016, 02:28 PM   #4
John Rambo
John Rambo's Avatar
Originally Posted by tumbla.jr View Post
You have a pm sir
Replied.
Old 04-01-2016, 03:53 AM   #5
John Rambo
John Rambo's Avatar
BUMP
Old 04-06-2016, 02:06 PM   #6
John Rambo
John Rambo's Avatar
Bumppp
Old 04-18-2016, 11:56 AM   #7
John Rambo
John Rambo's Avatar
Bump
Old 04-20-2016, 02:26 AM   #8
ZeroTo86
ZeroTo86's Avatar
Drives: '13 FR-S Turbo (Greddy T620z)
Pm'd
ZeroTo86 is offline   Reply With Quote
Old 04-26-2016, 01:57 PM   #9
John Rambo
John Rambo's Avatar
Bump!
socal: koyo radiator new SOLD toby714 Engine, Exhaust, Bolt-Ons 1 11-26-2015 08:15 PM
Koyo radiator, Venair hoses, Perrin oil cooler & pulleys, HKS inlet duct, G*S gaskets Turbowned Engine, Exhaust, Bolt-Ons 20 07-24-2015 11:59 AM
Fuel pump hanger assembly slicktop Want-To-Buy Requests 1 12-09-2014 03:23 AM
FS: Koyo Radiator and Invidia Over Pipe in Socal mtsui Engine, Exhaust, Bolt-Ons 4 09-25-2014 06:43 PM
Koyo Radiator vs Oil Cooler Captain Snooze Engine, Exhaust, Transmission 54 06-21-2013 11:18 PM
