Drives: 2015 Subaru BRZ series.blue
Fuel Pump Assembly Question
I recently removed my fuel pump assembly to siphon out my tank. After re-installing and filling tank back up with 10 gallons of fuel, my gauge only reads 1/2 full. Does anyone know if this has to do with how the tank transfers the fuel from one side to the other or does it have to do more with how I re-installed the assembly unit? Could there have been a possibility of the float getting moved around or something? I know I had to push down and twist the assembly a bit when I re-installed it. Anyone else run into this issue. Any help would be appreciated.
[insert cool phrase here]
Drives: BRZ Premium
Yep. Done screwed it. No worrries. It happens a lot when you mess with fuel pumps unknowingly.
Either buy new parts or try it again. Might want to re read the repair manual again, or take it to a shop.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
I'll vote for the "take it out and try again" approach.
humfrz |
Famous Potatoes
Drives: '15 ultramarine
Also note that there are many non-reusable parts when re-assembling.
I did not replace anything only pulled it out to siphon.
I did not repair anything, I just pulled out the assembly to place a siphon tube in the tank, so I could siphon the fuel. Perhaps the float got stuck on on something. I don't know, I may have to try to reposition it. Problem is, it's such a hassle to get the assembly in right each time.
Drives: 2015 Scion FRS
To rule out a faulty fuel level sensor, you can use a multimeter set to ohm's and check continuity while slowly sweeping the float up and down. See if there is a break in continuity. But sounds like you may have twisted it causing the terminals to not fully contact each other. Or pull the assembly out and see if the gauge reads full when you manually move the float.
#10 |
not playing cards
There's something weird about how the fuel level sensing works. Many people here have had issues with the not going to full because they were in the habit of topping off instead of running below a quarter tank.
I won't pretend to understand why but it's real. If you're pretty sure you got it together ok, maybe try just driving it empty and see if the system sorts itself out.
#11 | |
![]() humfrz |
#12 |
not playing cards
Well, until the idiot light comes on but I imagine you see those all the time.
#13 | |
![]() Stupid lights ........ back-in-the-day ....... I never had a problem remembering to bring my arm back into the car ...... humfrz |
#14 | ||
/dev/null
Drives: Uphill
WARNING: Metric system used in post.
Drive until it stalls? ![]() Quote:
In my estimate (and in my car) it comes on when there's between 10 and 12 liters left in the tank. That's 20% to 24% of a 50 liter tank. The light is useless. I've driven more than 80km with that light on and still only managed to cram 44 liters in there. |
| What is the secret to lining up the blue marks on the fuel pump assembly | amanzoli | Engine, Exhaust, Transmission | 1 | 01-04-2018 01:46 AM |
| Fuel pump assembly: Fuel pressure regulator popping out | sfruski | Engine, Exhaust, Transmission | 2 | 09-15-2017 09:39 PM |
| OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu | ndreim | Engine, Exhaust, Bolt-Ons | 5 | 11-23-2016 11:36 PM |
| FS SOCAL: Perrin Oil Cooler, Koyo Radiator, ECU, Stock Fuel Pump Assembly | John Rambo | Engine, Exhaust, Bolt-Ons | 8 | 04-26-2016 01:57 PM |
| Fuel pump hanger assembly | slicktop | Want-To-Buy Requests | 1 | 12-09-2014 03:23 AM |
