Old 01-09-2018, 01:32 PM   #15
Originally Posted by Sarlacc View Post
That's what I'd do.
Drive until it stalls?
You mean the low fuel warning light? That's very far from empty, you know.
In my estimate (and in my car) it comes on when there's between 10 and 12 liters left in the tank. That's 20% to 24% of a 50 liter tank. The light is useless.
I've driven more than 80km with that light on and still only managed to cram 44 liters in there.
"driving it empty" ...... how does one drive a car with an empty fuel tank ..?? Get it..?? No .. ?? Nobody "gets it" except me ....... what's wrong with you folks .....
(maybe I shouldn't have cut back on that expensive med ... ??)
Old 01-09-2018, 01:42 PM   #16
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Ah, a joke. Yes, I understand now. Hilarious!
The Following 2 Users Say Thank You to Sarlacc For This Useful Post:
humfrz (01-09-2018), Ultramaroon (01-09-2018)
Old 01-09-2018, 02:04 PM   #17
Well, it seemed funny ...... to me ...... at the time ....... but, not so funny this morning .......
Sarlacc (01-09-2018), Ultramaroon (01-09-2018)
Old 01-09-2018, 02:47 PM   #18
Much funnier when they have to be explained.
I'm guilty of being too terse. Inaccurate, actually.
If the issue is due to "works as designed," then running it below a quarter tank should do the trick. I haven't personally seen it but the topic has been discussed here a few times.
humfrz (01-09-2018), Sarlacc (01-09-2018)
Old 01-09-2018, 03:08 PM   #19
Welp, maybe we should just go back to having a reserve part of the gas tank, controlled by a simple little lever, pretty hard to mess that up ......
Old 01-09-2018, 07:30 PM   #20
amanzoli
amanzoli's Avatar
Drives: 2015 Subaru BRZ series.blue
I ended up removing the unit, making sure the float arm went in properly and did not get hung up on the hose inside the tank. . The actual inside of the tank is pretty shallow, so there is not a lot of space for the arm to hang down. Once you push the assembly down and compress it, you don't want to twist it more then necessary. It seems to be working now.
amanzoli is offline   Reply With Quote
Old 01-09-2018, 07:46 PM   #21
Grady
Grady's Avatar
Well, ya ........ there is the arrow one that points to the left ...... it pretty much blinks until I turn, then the one that points to the right starts blinking and blinks till mrs humfrz says something ......
You need to move to Dallas to fix that problem. You are not allowed to use them anywhere in Dallas county!
Old 01-09-2018, 08:25 PM   #22
Well ya, that makes sense. If you signal, that just signals the other drivers behind you of your intent, which gives them less time to close the gap before you can move in. ......
What is the secret to lining up the blue marks on the fuel pump assembly amanzoli Engine, Exhaust, Transmission 1 01-04-2018 02:46 AM
Fuel pump assembly: Fuel pressure regulator popping out sfruski Engine, Exhaust, Transmission 2 09-15-2017 10:39 PM
OEM: CHIRP-free high pressure fuel pump, camshaft assembly, stock injectors, ecu ndreim Engine, Exhaust, Bolt-Ons 5 11-24-2016 12:36 AM
FS SOCAL: Perrin Oil Cooler, Koyo Radiator, ECU, Stock Fuel Pump Assembly John Rambo Engine, Exhaust, Bolt-Ons 8 04-26-2016 02:57 PM
Fuel pump hanger assembly slicktop Want-To-Buy Requests 1 12-09-2014 04:23 AM
