#15 | |
Initial G
Drives: 13 FR-S, 15 BMW 228i
MR131's are 17.5lbs in that size, and $455 shipped to your door off Ebay, hard to beat that for perf/$.
2013 FR-S
2015 BMW 228i |
| The Following User Says Thank You to srt4evah For This Useful Post: | SuperTom (04-26-2018) |
#16 |
Drives: 2013 Hot Lava FRS
I'm really trying to stay away from motegi, xxr, rota etc. The only rep company i would consider going with would probably be varrstoen.
#17 |
Initial G
I am sure there may be people concerned about quality, but I've never broken a rim in a couple dozen cars I've had rims on (I'm 41), and frankly this entire SET of rims costs less than a single Advan. I could buy 2 sets of these for the cost of an RGII.
2013 FR-S
2015 BMW 228i |
#18 |
Yeah but most reps look horrible and that's mainly my issue with them other than weight.
#19 | |
Initial G
I really absolutely love the look of a nice set of 18s on the 86, but I just don't want to spend the $$$ on lightweight 18's and new rubber.
2013 FR-S
2015 BMW 228i |
#20 |
Drives: 2015 Scion FR-S
A gallon of gas weighs ~6.5 lbs. The FR-S has a 13.2 gallon tank. That means that a full tank weighs 85lbs more than a car without fuel. The full set of 15lb tires weigh 60lbs, so a full tank is like carrying around an extra set of light to medium weight tires. The difference between the 26lb heavy tires and the 15lb light tires is an additional 44lbs on the car.
Let's say you have half a tank of gas in your car, that means that you have 42.5 lbs less weight than you would with a full tank. That's basically the difference between the heavy and light tires you mentioned. So ask yourself: can you tell the difference between driving around with a full tank vs a half tank? For me, the answer was a definite no. |
#21 |
Drives: 86
That's not how it works.
| The Following User Says Thank You to monkeybike For This Useful Post: | Tristor (06-30-2019) |
#22 |
Drives: 2014 GT86
Byte11: differences between sprung, unsprung, and unsprung rotational masses and impact of lightening of those. I changed stock wheels (9.1kg each) to aftermarket ones of 6.2kg weight. The difference wasn't great (sometimes seeing it overexagerated), but i could feel it by 'butt dyno', how car accelerates/how suspension works over road defects. It may not be among best price/performancy investments, but if one seriously takes on lightening everything, certainly one of worthy application points.
#23 | |
Weight Weenie
Drives: 15 FR-S
| The Following User Says Thank You to new2subaru For This Useful Post: | G-Man (01-09-2018) |
#24 | |
Only happy when it rains.
Drives: series.blue
The less rotating parts weigh, the better. If that was not the case no one would buy RPF1's |
#25 | |
Drives: '13 Whiteout
#26 |
Driver
Drives: 2013 Whiteout FRS
Me, a guy swap wheel every 2 weeks for racing events. went from stocker to 17x8 GTF1, which is 15.6 lbs per wheel. wrapped in 225s. back and forth like 15 times
I do noticed the difference in accelerating. the car just feel "lighter". my recommendation...sound like you got alot of money to throw at it, go for 17in RPF1, Wedsport TC105n, or even those cheaper GTF1 720 Flowform perform extremely well. I've ride curb on race track with GTF1 and they held up pretty well.
#27 |
Drives: FRS
since OP said won't be tracking the car at all,
i say go for the ones you like based on looks. sure you can run with your asics - but you can also run with timberlands as well. feel heavier? sure but if youre not gonna track, i say rock those tims
'14 Scion FRS
Tein Flex TE37 |
#28 |
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The way I view it, for acceleration at least, is that wheels are basically levers. Making the wheel heavier is like using a heavier lever and where the weight is added on the lever *technically* makes a difference, but when each of the two rear "levers" are responsible for moving over 1300lbs, I don't know that adding 5 lbs anywhere on the lever makes an appreciable difference.
I think the gyro effect may be noticeable when turning the front wheels, but the bulk of resistance to forward motion comes from the mass of the car itself and small changes in wheel weight seem like "noise" when compared to the primary mass they must move. (In a straight line at least) |
| Will changing wheel width and offset affect alignment? | azynneo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 09-15-2017 01:46 PM |
| Am I missing something (fuel consumption vs performance vs weight) | GRoss | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 33 | 09-23-2014 03:34 PM |
| Ideal size width and weight for max performance | Boofneenee | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 11-29-2013 03:44 PM |
| Best light weight performance tire | brillo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 12-04-2012 02:24 PM |
