Old 10-27-2017, 11:30 AM   #15
srt4evah
Initial G
Drives: 13 FR-S, 15 BMW 228i
Originally Posted by Slammillionaire View Post
Based on the info in this thread, I'm probably gonna pick up some 17x9 gramlights. Thanks guys! lots of gr8 info.
I ended up with Motegi Traklite MR131's, 17x7 with 215 rubber. But I like to slide.
MR131's are 17.5lbs in that size, and $455 shipped to your door off Ebay, hard to beat that for perf/$.
2013 FR-S
2015 BMW 228i
srt4evah is offline   Reply With Quote
The Following User Says Thank You to srt4evah For This Useful Post:
SuperTom (04-26-2018)
Old 10-27-2017, 11:34 AM   #16
Slammillionaire
Slammillionaire's Avatar
Drives: 2013 Hot Lava FRS
I'm really trying to stay away from motegi, xxr, rota etc. The only rep company i would consider going with would probably be varrstoen.
Slammillionaire is offline   Reply With Quote
Old 10-27-2017, 11:44 AM   #17
srt4evah
Initial G
I am sure there may be people concerned about quality, but I've never broken a rim in a couple dozen cars I've had rims on (I'm 41), and frankly this entire SET of rims costs less than a single Advan. I could buy 2 sets of these for the cost of an RGII.
2013 FR-S
2015 BMW 228i
Old 10-27-2017, 11:54 AM   #18
Slammillionaire
Yeah but most reps look horrible and that's mainly my issue with them other than weight.
Old 10-27-2017, 12:01 PM   #19
srt4evah
Initial G
I will admit I don't really like the +45 look on these 17's, it's not terrible but it's not sexy, but they look better than stock imho and they're lighter. Suits my purposes, but everyone's got different plans.
I really absolutely love the look of a nice set of 18s on the 86, but I just don't want to spend the $$$ on lightweight 18's and new rubber.
2013 FR-S
2015 BMW 228i
Old 01-08-2018, 10:52 PM   #20
Byte11
Drives: 2015 Scion FR-S
A gallon of gas weighs ~6.5 lbs. The FR-S has a 13.2 gallon tank. That means that a full tank weighs 85lbs more than a car without fuel. The full set of 15lb tires weigh 60lbs, so a full tank is like carrying around an extra set of light to medium weight tires. The difference between the 26lb heavy tires and the 15lb light tires is an additional 44lbs on the car.
Let's say you have half a tank of gas in your car, that means that you have 42.5 lbs less weight than you would with a full tank. That's basically the difference between the heavy and light tires you mentioned. So ask yourself: can you tell the difference between driving around with a full tank vs a half tank?
For me, the answer was a definite no.
Byte11 is offline   Reply With Quote
Old 01-08-2018, 11:20 PM   #21
monkeybike
Drives: 86
That's not how it works.
monkeybike is offline   Reply With Quote
The Following User Says Thank You to monkeybike For This Useful Post:
Tristor (06-30-2019)
Old 01-09-2018, 12:39 AM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
Byte11: differences between sprung, unsprung, and unsprung rotational masses and impact of lightening of those. I changed stock wheels (9.1kg each) to aftermarket ones of 6.2kg weight. The difference wasn't great (sometimes seeing it overexagerated), but i could feel it by 'butt dyno', how car accelerates/how suspension works over road defects. It may not be among best price/performancy investments, but if one seriously takes on lightening everything, certainly one of worthy application points.
Old 01-09-2018, 07:18 AM   #23
new2subaru
Weight Weenie
Drives: 15 FR-S
Yes
The Following User Says Thank You to new2subaru For This Useful Post:
G-Man (01-09-2018)
Old 01-09-2018, 08:59 AM   #24
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
That is not how the math works. That weight in the gas tank is not being rotated, so its effect is a lot less.
The less rotating parts weigh, the better. If that was not the case no one would buy RPF1's
why? is offline   Reply With Quote
Old 01-09-2018, 09:46 AM   #25
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Go out and tape 44 lbs of lead weights on your wheels, go drive the car and report back.....
TommyW is offline   Reply With Quote
The Following 2 Users Say Thank You to TommyW For This Useful Post:
dattran86 (01-09-2018), Tristor (06-30-2019)
Old 01-09-2018, 10:34 AM   #26
dattran86
Driver
Drives: 2013 Whiteout FRS
Me, a guy swap wheel every 2 weeks for racing events. went from stocker to 17x8 GTF1, which is 15.6 lbs per wheel. wrapped in 225s. back and forth like 15 times
I do noticed the difference in accelerating. the car just feel "lighter".
my recommendation...sound like you got alot of money to throw at it, go for 17in RPF1, Wedsport TC105n, or even those cheaper GTF1 720 Flowform perform extremely well.
I've ride curb on race track with GTF1 and they held up pretty well.
Check out my website:
http://www.aim4apex.com/
IG: aimforapex
dattran86 is offline   Reply With Quote
Old 01-09-2018, 10:39 AM   #27
PeterFRS
PeterFRS's Avatar
Drives: FRS
since OP said won't be tracking the car at all,
i say go for the ones you like based on looks.
sure you can run with your asics - but you can also run with timberlands as well.
feel heavier? sure but if youre not gonna track, i say rock those tims
'14 Scion FRS
Tein Flex
TE37
PeterFRS is offline   Reply With Quote
Old 01-09-2018, 11:05 AM   #28
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
The way I view it, for acceleration at least, is that wheels are basically levers. Making the wheel heavier is like using a heavier lever and where the weight is added on the lever *technically* makes a difference, but when each of the two rear "levers" are responsible for moving over 1300lbs, I don't know that adding 5 lbs anywhere on the lever makes an appreciable difference.
I think the gyro effect may be noticeable when turning the front wheels, but the bulk of resistance to forward motion comes from the mass of the car itself and small changes in wheel weight seem like "noise" when compared to the primary mass they must move. (In a straight line at least)
Twinz is offline   Reply With Quote
Will changing wheel width and offset affect alignment? azynneo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-15-2017 01:46 PM
Am I missing something (fuel consumption vs performance vs weight) GRoss FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 33 09-23-2014 03:34 PM
Ideal size width and weight for max performance Boofneenee Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 11-29-2013 03:44 PM
Best light weight performance tire brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-04-2012 02:24 PM
