Old 12-02-2012, 11:14 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Best light weight performance tire
Looking around on tire rack, I'm not finding a performance tire in 245/40/17 (assuming most people want a little wider rubber) to replace the stock tires that is less than 20lbs. Looks like weight savings with wheels and tires is likely to come from wheels rather than tires.
So what is considered the best light weight rubber?
brillo is offline   Reply With Quote
Old 12-02-2012, 11:56 AM   #2
gmookher
you want/need that much tire? how much power are you making?
gmookher is offline   Reply With Quote
Old 12-02-2012, 12:20 PM   #3
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Michelin PSS is the lightest tire. I have the Hankook R-S3s, which are ultimately grippier, but abt 3-4 lbs more/tire.
GTB/ZR-1 is offline   Reply With Quote
Old 12-02-2012, 02:04 PM   #4
jeebus
Drives: 2015 Mustang GT (on order)
The ContiDW is 22lbs in that size.
jeebus is offline   Reply With Quote
Old 12-02-2012, 02:26 PM   #5
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
This, continental DW are usually the lightest i've seen in our sizes.
JoeBoxer is offline   Reply With Quote
Old 12-02-2012, 02:32 PM   #6
ngabdala
Vortech Supercharged
Drives: WRB BRZ 6MT LTD
Stock tire size but stickier tire
Powered by Vortech, ECS Tuning, and JDL Auto Design
ngabdala is offline   Reply With Quote
Old 12-02-2012, 02:34 PM   #7
ayau
Drives: Some rust bucket
Tire compound matters more than tire width if you want the most grip. I'd suggest oem size 215/45/17 star specs or rs3 tires. Going with 245 contDW won't give you as much grip and you're just adding unnecessary weight. Keep in mind that if you go wih wider tires, you'll need wider rims as well. This all adds up to more weight.
Wider does not equal better.
Old 12-02-2012, 03:19 PM   #8
FreshFRS
KCCO From Canada
Drives: Asphalt FRS
i agree that compound is more important than width however you dont have to give up weight for width too much.
Continental DW 245/35ZR18 are 20.2lbs or the same as stock. finding any 18" wheel less than 20lbs means overall lighter. i'm ordering 18x8 CE28N (14.7lbs) so combined they save 6.5lbs per corner by my scale.
I'm going 18 because it think it will ultimately look better and 6.5lbs per corner is great when going plus size tire and wheels.
The wider contact patch can mean more grip at launch as well as better cornering potential even with a less grippy tire. DW's aren't terrible and they last a long while, they aren't at the same level as the other two though (almost R compounds) but a 245/40R17 starspec is going to out perform a 215/45R17 most likely as well.
IMHO star specs and RS-3 are great tire options but they wear too fast for a mostly street driven car. (i know ran them on my S2k) PSS are a better option for those who want longer wearing tires with awesome grip, continentals are even longer wearing while not giving up too much grip to the PSS. My choice is either PSS or DW for those reasons. I ran all 4 of these tires on my S2k in the 5 years i had it.
FreshFRS is offline   Reply With Quote
Old 12-02-2012, 05:05 PM   #9
GTB/ZR-1
GTB/ZR-1's Avatar
Interesting note.
I installed Weds 17x9" rims w/ 245-17 Hankook R-S3s.
The weight between this setup & the factory setup was within 1/2lb per corner, AND 3.2(!) secs on a ~40+ sec AutoX course, same day, same driver (BRZ was there w/ completely stock & my car just had rims/tires--no alignment mods etc).
I'm going to say that was a fair tradeoff...
Old 12-02-2012, 06:29 PM   #10
ayau
Keep in mind that if you go with wider tires, you have to run them harder to reach its optimal operating temperature. In normal day to day driving, you won't reach optimal temps, and that's why going with slimmer tires is sometimes the better option.
Also, a more aggressive alignment can also add more cornering capabilities.
Old 12-04-2012, 05:07 AM   #11
Blue86
Drives: Sonic Blue 86GT Manual
Originally Posted by Vaishali View Post
Metzeler is the best light weight rubber tire. I have used Metzeler tires in my Harley Davidson V ROD. This tires have always satisfied motorcyclists demands for innovation. Metzeler Motorcycle tires are undoubtedly one of the best performing tires in history.
That's good to know. I'm going to put motorcycle tyres on my car now
Blue86 is offline   Reply With Quote
Old 12-04-2012, 02:24 PM   #12
SakDiesel
SakDiesel is offline   Reply With Quote
Has anyone install a light weight flywheel? 20valvewynn83 Engine, Exhaust, Transmission 44 08-08-2013 09:52 PM
Light Weight Fly Wheel denverizzles Engine, Exhaust, Transmission 13 12-03-2012 02:28 PM
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Sard light weight flywheel Turdinator Engine, Exhaust, Transmission 4 10-30-2012 08:53 PM
