Old 09-08-2014, 07:30 PM   #1
GRoss
Drives: Subaru Impreza 2.0i-L 2012
Question Am I missing something (fuel consumption vs performance vs weight)
Hi all,
This is by no means a thread to bash the gt86 and I am a big fan of it myself, even though I don't own one. I think the gt86 is a fantastic looking car, handles great and has just about adequate power. I'm currently at a stage of really wanting one, but hoping to hold out until the *hopefully* larger displacement/turbo charged version comes out.
The problem that I do have with the gt86 is a weight to power to fuel economy ratio. I've been looking at the fiesta st and mazda 3 sp25 as it's direct competitors (for me at least). Have a look at the table below:
Can somebody explain on why, while making such modest power/torque figures, is it sipping 1.5 l/100km more than the other cars, which is made even worse by the fact that it needs 98 octane fuel, compared to 91 for other cars. For such a small car, using up so much fuel is pretty... terrible in my opinion (I've got a 2012 Impreza which is using around a litre less - 91 octane as well).
My other question is the weight - almost every single review I've read, it was mentioned about how lightweight and small the gt86 is. Small is true, but lightweight - hardly. Again - look at the table above - weighting around 50 kg less than 4 door mazda 3 is hardly lightweight.
Once again - not bashing the gt86 in any way - just wanted to see what others thought about those 2 points.
Edit: posted in the wrong forum by accident - can somebody please move it to general discussion or vs forum please?
GRoss is offline   Reply With Quote
Old 09-08-2014, 07:34 PM   #2
904FRSlow
904FRSlow's Avatar
Drives: '13 FR-S Whiteout
We use 93 octane though and the manual does 0-60mph way faster than 7.4 seconds
904FRSlow is offline   Reply With Quote
Old 09-08-2014, 07:42 PM   #3
solus
Drives: 2014 Scion FRS (Ultramarine)
Rants about fuel consumption.... Wants turbo version. Pfft
solus is offline   Reply With Quote
The Following 2 Users Say Thank You to solus For This Useful Post:
Jrryjms07 (09-08-2014), tinma (09-12-2014)
Old 09-08-2014, 07:45 PM   #4
GRoss
Hmm - I'm just going by what's written in the official specs on Toyota Australia website for the RON rating. The 0-100 times are from a few reviews, including this one (go to 3:12):
[ame="https://www.youtube.com/watch?v=DYrvhkIivgA&list=PLNy4MIqFoWYXvkzp5fpJti_w OTyp6rrQp#t=192"]Epic Scion FR-S, Toyota GT86 test drive: racetrack, drift & cross-continental dash - HD - YouTube[/ame]
And yes - I am ranting about fuel consumption, even though I want a turbo. Fiesta ST has a turbo - great fuel efficiency!
Old 09-08-2014, 07:52 PM   #5
jvincent
jvincent's Avatar
The turbo in the ST is the main reason. Toyota wanted the 86 to be a NA engine. If they had wanted better power numbers a 1.8l Turbo would have worked perfectly.
Old 09-08-2014, 08:09 PM   #6
GRoss
I'm happy with no turbo, but that's what I don't understand - looking at the Mazda 3 SP25 - it has a 2.5L engine which returns much better numbers both performance and fuel economy wise, than the 2.0L in the 86. Why is that?
Old 09-08-2014, 08:54 PM   #7
jvincent
jvincent's Avatar
The Mazda has better torque low down, which is probably why it has a better 0-100 time, but it makes less peak power.
If the gear ratio in 6th is different that would affect the highway mileage rating.
Old 09-10-2014, 04:50 PM   #8
aristo
aristo's Avatar
Drives: BRZ SWP 14
Our cars are prettier. Also I think adding the msrp for base models would be even better because I think we are the most expensive of the three as well
Good post
aristo is offline   Reply With Quote
Old 09-11-2014, 04:16 PM   #9
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Smaller engines with tiny turbos usually get better gas mileage than high output, larger liter 4 cylinders. Cruising the turbo actually helps with gas mileage.
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
gt8613 (11-03-2014)
Old 09-11-2014, 04:41 PM   #10
CoupedUpSubie
Drives: 2013 BRZ Limited
The answer is you are comparing 3 cars which ultimately are in 3 different classes. The fiesta is a hot hatch and should be compared to the mini. The Mazda 3 is a four door small family sedan. The 86 is a two door car which is built for handling and enjoying the drive.
As for the weight, I'd much rather end up in a accident with an 86 then a Mazda or ford. The 86's unibody is built off of subarus ring design. Also I'm sure it has the boron bars and multi layered a pillars like all the other cars subaru produces.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
nikitopo (09-23-2014)
Old 09-11-2014, 05:05 PM   #11
stonenewt
Drives: BMW 120d
In the EU there are 'games' that manufactures play to reduced tested emissions levels but are unrealistic for normal driving.
I think it was a fiesta ST (or maybe a Zetec S 1.0 EcoBoost) that was telling me to up shift when the next gear would be at around 1100rpm. Absolutely no torque and the engine was very uncomfortable at those rpms. Anyway the ST doesn't get close to its advertised EU economy figures.
We never got the SP25 here. The petrol Mazda 3 2.0 I drove was massively over geared, again its official economy figures were a joke. BTW in the UK the 2.0 Sports-Nav weighed in at somewhere north of 1400kg, but the maximum towing weight was 1300kg, are you sure you've got the right weight for the car?
The twins have lower, decent drivers car ratios which for the EU cycle will show higher fuel usage, but actually the figures will be much more realistic because the gear ratios are in a much more natural position.
As for 0-60 times, utterly useless IMO 10-60 through the gears is a much more realistic value & if you can work out these timings make HUGE differences to the acceleration times.
My 2p
stonenewt is offline   Reply With Quote
Old 09-11-2014, 07:48 PM   #12
tonyfrs86
tonyfrs86's Avatar
Drives: 2013 raven frs
I'm in the states running 92. I'm also turbod with the AVO kit. I get 38mpg on the freeway just cruising. Get 27mpg in the city. Mine is auto so i get a little better fuel consumption. I don't know what that converts into liters cuz 'MERICA!
tonyfrs86 is offline   Reply With Quote
Old 09-12-2014, 12:20 PM   #13
extrashaky
Drives: 2014 BRZ Limited
Yes. It's this:
... even though I don't own one.
If you did, you wouldn't be asking these questions. You would instinctively understand that this car is greater than the sum of a bunch of numbers.
Old 09-21-2014, 11:16 PM   #14
GRoss
Thanks for your replies guys! Really interested to hear your thoughts
Once again - I'm not trying to bash the GT86 - I love that car, I'm just trying to get some opinions on a subject that has been puzzling me for a while now.
Getting back to the fuel economy figures - what originally raised that question was the fact that I own a 2012 Impreza myself. I'm sure many of you know that it has the same displacement engine as the GT86 - both 2.0L. Difference is the different bore and stroke + direct injection for the 86. And I guess the biggest concern that I had is that a small 2 door coupé is chewing up more, higher RON petrol than a larger, all wheel drive sedan.
Don't really know much about different body designs for different brands, but I doubt that you will fare much better in a low coupe, compared to a larger sedan (mostly talking about Mazda here).
How much fuel consumption difference: 1 person vs. 2 people djmm Scion FR-S / Toyota 86 GT86 General Forum 19 04-30-2014 04:33 PM
Fuel consumption figures too PuGZoR AUSTRALIA 25 02-16-2014 05:36 PM
Tyre Pressures/Fuel Consumption Vic_RSA AFRICA 11 12-11-2012 01:20 PM
Best light weight performance tire brillo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-04-2012 02:24 PM
Weight, fuel consumption and 0-100. Loki556 AUSTRALIA 15 07-16-2012 09:06 PM
