Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
12-19-2017, 11:03 AM | #15 |
This^
If the bodies are not wrapped as per Toyota directions (including handbag placement) then they can be noisy.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
12-19-2017, 11:36 AM | #16 | |
Drives: Toyotas 86 (2013) & RunX RSi (2003)
I do believe rattles are standard for our cars, but heavier clunking may be something worth finding out Sent from my HUAWEI VNS-L31 using Tapatalk |
12-19-2017, 11:39 AM | #17 |
Drives: 2013 FR-S in Asphalt
12-19-2017, 11:51 AM | #18 |
helmholtz resonator
Drives: '15 ultramarine
The Following User Says Thank You to Sapphireho For This Useful Post: | Ultramaroon (12-20-2017) |
12-19-2017, 12:54 PM | #19 | |||
Drives: Toyota GT86 Limited Edition
I see you are a rookie, there should be no bodies left if you did a good job ... ... ... |
12-19-2017, 02:12 PM | #20 | |
So not the TRD so we can rule that out. All your exhaust hangers are in place and hooked up?
12-19-2017, 02:30 PM | #21 | |
I am a bit of a tubby-bastard ... So I will have to take it to a shop and get it on a lift to see that ... Will let you know by end of the week |
12-19-2017, 03:34 PM | #22 | |
The sound you hear is just the rear suspension hitting on the bump stops ..... humfrz |
12-19-2017, 03:46 PM | #23 |
Drives: '13 FRS - STX
Something is loose, the swaybar end link or the damper top mount are the most likely to cause noises.
The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (12-19-2017) |
12-19-2017, 04:29 PM | #24 |
Resident Wookie
Drives: 2013 SWP Limited BRZ
Yeah, you should have the handle unless the previous owner decided he was going to ferry hostages around in the boot.
12-19-2017, 04:47 PM | #25 |
He is in South Africa. The cars are equipped differently in different markets.
The Following User Says Thank You to Tcoat For This Useful Post: | Shaisters (12-19-2017) |
12-19-2017, 11:54 PM | #27 | |
12-20-2017, 01:03 AM | #28 |
chicken tonight
First time I heard the rear deck pop I looked all over underneath the car for a wire or something light smacking the inside of a rear wheel well or under the trunk.
Sounds exactly like that. If you reach up from inside the trunk and tug back and forth a little on the spot welds, I bet you can reproduce the sound at will. If confirmed, I suggest just leaving it alone. No need to go bending open seams. The spray sealant will eventually harden after a couple summers and the sound will stop. Even before it stopped, I felt a lot better just knowing what it was.
The Following User Says Thank You to Ultramaroon For This Useful Post: | chaoskaze (12-26-2017) |
Similar Threads | ||||
Knocking sound | Moe23 | Issues | Warranty | Recalls / TSB | 80 | 04-18-2019 08:09 PM |
Unidentified knocking sound | Maarten | Engine, Exhaust, Transmission | 5 | 04-10-2019 11:40 AM |
knocking sound holding around 3,000rpm | radroach | Issues | Warranty | Recalls / TSB | 31 | 01-26-2018 01:03 AM |
knocking sound | wingrider | Engine, Exhaust, Transmission | 12 | 08-22-2016 12:35 AM |
Knocking sound from AC? | DCdesign2000 | Issues | Warranty | Recalls / TSB | 2 | 09-25-2015 09:09 PM |
