Old 12-19-2017, 12:03 PM   #15
Originally Posted by Beachin86 View Post
Have you checked the trunk for dead bodies? .
This^
If the bodies are not wrapped as per Toyota directions (including handbag placement) then they can be noisy.
chaoskaze (12-26-2017), MileMonger (12-20-2017), Spuds (12-19-2017)
Old 12-19-2017, 12:36 PM   #16
noodlefish
noodlefish's Avatar
Drives: Toyotas 86 (2013) & RunX RSi (2003)
Have you checked the trunk for dead bodies? Kidding, but let us know what the cause is once you find out. I hear all kinds of noise in my FR-S but just kind of tune it out now.
Without the seats down you have to do some serious, uh, "rearrangement" with the body parts to get them in the trunk.
I do believe rattles are standard for our cars, but heavier clunking may be something worth finding out
Sent from my HUAWEI VNS-L31 using Tapatalk
noodlefish is offline   Reply With Quote
Old 12-19-2017, 12:39 PM   #17
Qadthane
Qadthane's Avatar
Drives: 2013 FR-S in Asphalt
Finally! I was starting to lose faith in this group.
Qadthane is offline   Reply With Quote
Old 12-19-2017, 12:51 PM   #18
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
..If the bodies are not wrapped as per Toyota directions (including handbag placement) then they can be noisy.
Only a complete rookie would leave the bodies unwrapped.
Ultramaroon (12-20-2017)
Old 12-19-2017, 01:54 PM   #19
Emissary_of_Pain
Emissary_of_Pain's Avatar
Drives: Toyota GT86 Limited Edition
Originally Posted by Shaisters View Post
Does your car have the little emergency escape handle on the inside of the trunk hatch? Mine always pops out of place and makes an annoying plastic hitting metal sound.
No handle for me ... looks like the previous owner skimped on the extras ... haha ... Didn't even get the TRD springs
I ... Uh ... Trunk is ... Clean ... I meant clear ... Like ... Uh ... Devoid of bodies
This^
So this whole time I have been doing it wrong, who knew all I needed was a damn handbag !!
I see you are a rookie, there should be no bodies left if you did a good job ... ... ...
Emissary_of_Pain is offline   Reply With Quote
Old 12-19-2017, 03:12 PM   #20
The handle is a requirement here not really an extra.
So not the TRD so we can rule that out.
All your exhaust hangers are in place and hooked up?
Old 12-19-2017, 03:30 PM   #21
Emissary_of_Pain
I am a bit of a tubby-bastard ... So I will have to take it to a shop and get it on a lift to see that ... Will let you know by end of the week
Old 12-19-2017, 04:34 PM   #22
NOW you tell us .........
The sound you hear is just the rear suspension hitting on the bump stops .....
Old 12-19-2017, 04:46 PM   #23
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Something is loose, the swaybar end link or the damper top mount are the most likely to cause noises.
ineedyourdiddly
Tcoat (12-19-2017)
Old 12-19-2017, 05:29 PM   #24
Shaisters
Resident Wookie
Drives: 2013 SWP Limited BRZ
Yeah, you should have the handle unless the previous owner decided he was going to ferry hostages around in the boot.
Shaisters is offline   Reply With Quote
Old 12-19-2017, 05:47 PM   #25
He is in South Africa. The cars are equipped differently in different markets.
Shaisters (12-19-2017)
Old 12-19-2017, 06:00 PM   #26
Shaisters
Resident Wookie
I forgot that happens a lot in RSA.
The Following User Says Thank You to Shaisters For This Useful Post:
Tcoat (12-19-2017)
Old 12-20-2017, 12:54 AM   #27
noodlefish
noodlefish's Avatar
Can confirm, I actually looked for a handle for about 6 minutes since I've read that it should be there. But it's nowhere to be found. Good thing I didn't go the lock-myself-in-trunk method to test this. Maybe it's just not a big deal here in SA
Old 12-20-2017, 02:03 AM   #28
First time I heard the rear deck pop I looked all over underneath the car for a wire or something light smacking the inside of a rear wheel well or under the trunk.
Sounds exactly like that.
If you reach up from inside the trunk and tug back and forth a little on the spot welds, I bet you can reproduce the sound at will. If confirmed, I suggest just leaving it alone. No need to go bending open seams. The spray sealant will eventually harden after a couple summers and the sound will stop.
Even before it stopped, I felt a lot better just knowing what it was.
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 09:09 PM
Unidentified knocking sound Maarten Engine, Exhaust, Transmission 5 04-10-2019 12:40 PM
knocking sound holding around 3,000rpm radroach Issues | Warranty | Recalls / TSB 31 01-26-2018 02:03 AM
knocking sound wingrider Engine, Exhaust, Transmission 12 08-22-2016 01:35 AM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 10:09 PM
