Old 08-21-2016, 06:50 PM   #1
wingrider
Drives: subaru brz
knocking sound
Hi Everyone,
After i have driven for about 7-8 miles, when I shut down the car I hear knocking sounds from the engine. The knocking sound continues for a couple of minutes. This is the first car I have owned and I don't know if this is something I need to be worried about. I use chevron fuel with 92 octane rating if that helps.
I am adding a sound clip of the knocking sound. Any tips will be much appreciated.
sound clip
Thanks,
WingRider.
wingrider is offline   Reply With Quote
Old 08-21-2016, 06:58 PM   #2
FRS Justin
Drives: 2013 Asphalt FRS
It sounds like the heat shields cooling off on the exhaust. I wouldn't worry about it, its normal.....
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
humfrz (08-21-2016)
Old 08-21-2016, 07:16 PM   #3
wingrider
Drives: subaru brz
Thank you very much for the quick reply!
The Following User Says Thank You to wingrider For This Useful Post:
FRS Justin (08-21-2016)
Old 08-21-2016, 07:24 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I have never heard heat shields THAT loud. There's something else going on. You need to crawl around and find out where the noise is coming from. Is it from the engine, underneath or somewhere else?
Heat shields contracting is normal and every car does it, but it's not very loud and every car does it.
Old 08-21-2016, 07:42 PM   #5
FRS Justin
The recording is loud but that could be his recording device and where he held the mic, he could also have turned the mic gain up. If he is not over heating or any other problems I would say all in all its a heat shield noise... nothing to worry about
710whp
Old 08-21-2016, 07:42 PM   #6
humfrz
Hello @wingrider and welcome to the sounds of the FR-S/BRZ.......
Yep, I reckon @FRS Justin has it diagnosed proper.
humfrz
Old 08-21-2016, 07:47 PM   #7
humfrz
DANG, @guybo ........ clean the wax out of your ears ........ or, maybe your car didn't come with the optional, high volume heat shields ........
humfrz
Old 08-21-2016, 07:52 PM   #8
wingrider
Drives: subaru brz
I used the sound recorder android app. Don't know if it turns the the gain up. I feel that it comes from the engine. Really noob question: you said its the heat shields cooling off the exhaust. Does it mean it will be louder at the back of the car at the exhaust? I can verify that.
The car does not overheat and runs beautifully. Its a joy to drive
Old 08-21-2016, 07:58 PM   #9
guybo
Huge E85 fan!
guybo's Avatar
Yeah, maybe it's the recording. the OP should measure the noise of his car against others though. When my car is turned off hot, it's no louder than other cars.
Mine came with extra crickets that drown out the high volume heat shields. CWA trump HVHS any day.
humfrz
The Following User Says Thank You to guybo For This Useful Post:
humfrz (08-21-2016)
Old 08-21-2016, 09:38 PM   #10
FRS Justin
here is a collection of heat shields
https://www.google.com/search?q=frs+...+shields&imgrc=_
they surround the exhaust pipe to dissipate the heat. It should actually be quieter towards the back because the heat has mostly dissipated...
710whp
Old 08-21-2016, 10:16 PM   #11
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
I would bet money that is drops from the AC line. Water hitting the exhaust. There is a small black tube that drains most of the water coming down under the passenger side floor board. maybe that is clogged. I have never heard my brz make this noise but i have absolutely heard it on many other vehicles. Sounds just like Water from the AC dripping on the exhaust.
tofurun is offline   Reply With Quote
Old 08-21-2016, 11:22 PM   #12
churchx
churchx's Avatar
Drives: 2014 GT86
It sounds loud .. but is it loud or just such recording loudness level? When i park mine, yes it ticks/knocks, when cooling down, but not that easy to gauge how that "not that loud" on mine is vs this recording, by trying to scale it to other ambient sounds recorded.
The Following User Says Thank You to churchx For This Useful Post:
FRS Justin (08-22-2016)
Old 08-22-2016, 12:35 AM   #13
humfrz
After a second listen, it sounds like hail on the tin roof of an empty chicken coop.
If the OP was from Georgia ....... I would figure that's what it was ......
OK, I deserved that.
humfrz
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
knocking sound holding around 3,000rpm radroach Issues | Warranty | Recalls / TSB 31 01-26-2018 01:03 AM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 09:09 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Knocking sound in wheels during driving WallsAndFoundations Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-28-2014 12:45 AM
