Old 10-12-2017, 03:54 AM   #1
Maarten
Drives: Silver GT86 2013
Unidentified knocking sound
I need some help:
Heavy clunking noise, increases the longer I drive.
Gets louder when I turn right.
The sound is a loud knocking and I can feel the vibrations through the entire car.
Seems to be coming from the rear.
With windows open it sounds like a metallic clunk
Seems speed related. But also reduces on Cruising speed. (so worst when accelerating or decelerating)
Things inspected:
Axles are good
Driveshafts is good
No play on wheelbearings or suspension
No metal shavings on differential magnet plug
Same issue with original wheels
Noise started on the way home from drift event. At that moment I had some vibrations from dirt inside the wheels.
No noise or strange behavior during drifting event.
Car specs :
2013 model
Kw v3 coilovers
Full exhaust
8.5j front 9.5j rear
Update:
Since I was back home for 2 days I went to pick up the car from the dealer again as they still couldn't find the issue. So I went for a drive through the hills.
For the first 1.5h I had no issue what so ever. No noise, no strange feeling.
Then it started coming back slowly. First I felt like a little vibration when doing a right hand corner. Then the sound started becoming louder and louder.
I found a small drift spot and did some figure eights. Result, no noise during drifting.....
Besides that the sound got worse and worse the more I drove it.
The day after I went to the store (15 min drive). Again sound or vibration.
Maarten is offline   Reply With Quote
Old 10-12-2017, 08:58 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
By chance did you changed to different wheels at event? Are wheel lugnuts retightened after some mileage?
(that assuming that there really is no play at any suspension bushing)
Old 04-09-2019, 08:30 AM   #3
maicolp
Drives: toyota gt86 1st edition
same here... keep me updtaded
maicolp is offline   Reply With Quote
Old 04-09-2019, 09:36 AM   #4
Long shot but possible:
I broke a belt in a tire on my Talon once. Nothing visible and all was smooth until I drove for a bit and the tire warmed up. Symptoms were similar to those described. The only way we figured it out was when I swapped the tires rear to front and the condition moved with it. Pulled the tire and it was a mess inside even though the outside looked fine.
Old 04-09-2019, 11:53 PM   #5
humfrz
After that, you started buying NEW tires?-
humfrz
Old 04-10-2019, 11:40 AM   #6
Tristor
Tristor's Avatar
Drives: 2017 Subaru BRZ Limited
Have you inspected the rear coilovers? Clunking sounds like it could be either settings or condition of the dampers. I'd also inspect specifically the top hats, ensure that the top nut is fully tightened and has not backed off.
Clunking from the rear when you're turning right tells me it's probably on the rear right (passenger) side, because weight shifts in a turn.
Tristor is offline   Reply With Quote
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 08:09 PM
knocking sound wingrider Engine, Exhaust, Transmission 12 08-22-2016 12:35 AM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 09:09 PM
Knocking doesn't sound good :-(. TheMarkness Issues | Warranty | Recalls / TSB 41 02-04-2015 10:38 PM
Knocking sound in wheels during driving WallsAndFoundations Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-28-2014 12:45 AM
