Old 10-04-2017, 06:56 PM   #29
Originally Posted by dowroa View Post
You got anything else, @Ultramaroon?.
I think you pretty much nailed it. If the slotted rotor is not as thick or offset too deeply it would create a wider gap. I'm always suspicious of aftermarket parts.
Old 10-04-2017, 09:21 PM   #30
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
What you did was buy a non vented rear rotor. The base model in some countries have a solid rear rotor with different (narrower) rear calipers. Your pad wore down to the point where it was no longer contained. Stock width rotors will hold a baking plate in place, I've worn them down to nothing on track and never had an issue.
Let me guess, DBA?
Edit: looks more like stoptech slots
Decay107 is offline   Reply With Quote
The Following User Says Thank You to Decay107 For This Useful Post:
Ultramaroon (10-04-2017)
Old 10-05-2017, 10:59 AM   #31
jasonojordan
Drives: 2013 satin white brz limited
Let me guess, DBA?
Your edit is correct. They are stoptech slotted. So that said should I be concerned the rotors that I have on there will do the same thing to the new set of pads? As I stated all the pads on there were still at 3/4" life so for that to happen with that much pad life I was really confused. Now if they were mm from the squeakers or down to bare metal I could see what your saying being something to get worried about.
jasonojordan is offline   Reply With Quote
Old 10-05-2017, 11:14 AM   #32
dowroa
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
Yes if the overall width is incorrect.
However, you can quickly and easily go to any auto parts store, get a pair of OEM rotors for 40-60 USD each and put them on and be done with it.
dowroa is offline   Reply With Quote
Old 10-05-2017, 11:31 AM   #33
jasonojordan
Can anyone post up the standard rear disk thickness and I will measure where mine are at tonight with a caliper.
Ones I have are 126.47031SR They are a Vented disc. That said we all know that when some companies say direct OEM replacement that can be not always the case.
Old 10-05-2017, 02:47 PM   #34
fx1mark
fx1mark's Avatar
Drives: red 2014 FR-S
Here you go.
fx1mark is offline   Reply With Quote
The Following User Says Thank You to fx1mark For This Useful Post:
jasonojordan (10-05-2017)
Old 10-05-2017, 02:58 PM   #35
jasonojordan
Originally Posted by fx1mark View Post
Here you go.
Online it has it listed for my rotors from factory as a nominal 18mm thickness minimum of 16mm thickness. I will measure mine when I get home and see where we are at and report back
Old 10-05-2017, 06:53 PM   #36
jasonojordan
We might have a winner. Rotors are solid in the rear. 9.5mm is the average thickness.
Old 10-05-2017, 08:13 PM   #37
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Ding Ding - Fries is done.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post:
jasonojordan (10-05-2017), venturaII (10-06-2017)
Old 10-06-2017, 03:22 PM   #38
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
And fire your friend who did the brake work for not realizing he was replacing a vented rotor with a solid one.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 10-06-2017, 04:05 PM   #39
jasonojordan
To be fair I was there to so can't place the blame souly on him.
Old 10-06-2017, 05:39 PM   #40
Capt Spaulding
Persona Non Grata
Sure you can. Arrange to have a bus drive by your house so you can toss him under it.
Ultramaroon (10-06-2017), venturaII (10-06-2017)
Old 10-06-2017, 05:53 PM   #41
jasonojordan
haha I guess sure. Never been like that though. I have no problem admitting when I make a mistake stupid or other wise.
The Following User Says Thank You to jasonojordan For This Useful Post:
Capt Spaulding (10-07-2017)
Old 10-06-2017, 08:17 PM   #42
lol
Feeling the love.
1uz fell in my lap rucfj159 Forced Induction 7 12-20-2016 08:03 PM
Tree fell on my car brandonblt2 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 20 10-31-2015 07:06 PM
Fell in love all over again... ericmpena BRZ First-Gen (2012+) — General Topics 23 01-22-2014 04:29 AM
NEED HELP BACK UP LED ( fell in housing ) 21_nola_05 Cosmetic Modification (Interior/Exterior/Lighting) 7 01-08-2014 05:53 PM
Piece of my car fell off..... Mac1235 Issues | Warranty | Recalls / TSB 5 04-15-2013 02:21 PM
