#337 |
Drives: C5, GT-86, '24 Colorado TrailBoss
#338 |
Drives: frs
Or he is on a Hospital or he will ditch the platform. I want a review like he did on v2, dynos comparisons and all that kind of crap.
| The Following User Says Thank You to Teseo For This Useful Post: | nikitopo (09-17-2017) |
#339 |
Drives: 2017 BRZ w/PP
its actually looking better now but still slightly rich. im going to drive out to a friends so im going to try some highway pulls. here were my last 3 logs http://datazap.me/u/gnuworldorder/lo...5?log=0&data=1
#340 | |
Drives: FT86
ok here is open loop fuel maps and WOT fuel map you cannot see in the tune so it lloks like its doing what shiv intended ie its arround 11.7 full load high rpm. You likely going to have to ignore the logged parameters "commanded AFR" as i looks like its not logging the true commanded afr. also IAM from memory as it was logging a zero and incorrect |
| The Following User Says Thank You to steve99 For This Useful Post: | Breadman (09-17-2017) |
#341 |
Drives: FT86
Stock K00C fuel mapping for comparision
#342 |
Drives: Toyota 86 GTS
OFT has never once logged true commanded afr, you know this already steve.
#343 |
Drives: FT86
#344 |
WRBLUE BRZ
Drives: 2016 Subaru BRZ
Is it possible to have a tactrix tutorial for beginner ?
Only one reason I bought OFT because there are many guide about OFT. |
#345 | |
- Select BRZ - Add or copy definition if required - Always select yes to correct checksums No more easy or complicated than OFT, just different. There's very little point unless you have the logger definitions for your calibration though, or you simply flash and log EU rom. |
| The Following User Says Thank You to Wayno For This Useful Post: | pym19109 (09-17-2017) |
#346 | |
WRBLUE BRZ
#347 |
Why? OFT is the only one you can have realtime display and log simultaneously. One isn't better than the other, they just have different uses.
#349 | |
#350 | |
Also, It is so funny to see many of my local friends who have Ecutek in there 86 saying Ecutek is much better than OFT while none of them do even a single data logging. 나의 SM-N950U 의 Tapatalk에서 보냄 |
| The Following User Says Thank You to nunonuna For This Useful Post: | Teseo (09-17-2017) |
| OpenFlash Tablet: Multiple Data Log files! | Shiv@Openflash | Software Tuning | 95 | 11-09-2017 08:40 AM |
| OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download | Shiv@Openflash | Software Tuning | 1062 | 08-13-2017 04:13 PM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet v1.55b: BIN files added! | Shiv@Openflash | Software Tuning | 525 | 04-09-2014 09:42 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
