Old 07-25-2014, 02:51 PM   #1
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Smile OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download
Hi guys,
We just want to thank you guys for the support you have shown to OpenFlash team over the last year. We are thrilled to have thousands of happy OpenFlash Tablet owners out there. It keeps us doing what we love! And in this case, it's releasing new maps for you guys to enjoy! A whole lot of them. This is the biggest map release in our history. Currently, they are only for USDM cars. But we will be expanding to support non-USDM cars in the next couple of weeks.
But for now....
v2.0 BETA DOWNLOAD LINK (bottom of page)
132 new maps
-Stage 1, Stage 2 EL, Stage 2 UEL, Stage 2 EL E85, Stage 2 UEL E85
-91oct, 93oct and E85
-Support for 700C, 900C, A00C, A01C, B00C, B01C, 700D, 900D, A00D, A01D, B00D and B01D
Launch control and No Lift Shift is available in all 6MT ROMs.
All ROMs based upon the newest B01C and B01D factory software (for smoother idle and better drivability).
12 new XML files
-If you want to view and/or edit any of the v2.0 OTS maps, you MUST USE THESE XML FILES. This means you will need to delete the old XML files from your ROM Raider database.
-Tuner Pro mapping software is no longer supported so please don't use it.
Not following these instructions and editing with old XMLs may result in ECU failure (dun dun dunnnn).
Of course, if you do not want to edit/view the OTS maps, you don't need to do anything with the new XML files. Just upload the OTS maps through OpenFlash Manager and flash your ECU as usual
Have a great weekend!!
Cheers,
Shiv, Robert and Garrett
OpenFlash Team
Edit: Looks like I gave you guys the XMLs that don't have Launch Control or Flat Foot shift defined. Sorry about that. So I just created a v2.01 download which has the LC/FFC XMLs included. No difference in maps so no need to reload v2.01 maps if you already loaded up a v2.0 map.
Edit (8/4/14): v2.02 just released. Only change is that ZA1JD00C (2015 USDM 6MT) OTS Maps/XML support was added to download folder.
Edit (8/5/14): 8/05/14
v2.03b Released
-Revised ZA1D00C XML that fixes minor definition errors.
-Revised Stage 2 E85 UEL D00C and Stage 2 E85 EL D00C files with corrected cranking enrichment values
Edit (8/15/14):
v2.04b
-Add tuned ROM support for ZA1JD00G (EU 6MT) and ZA1JA2A (DOM 6MT) Calibration IDs.
-XML files for ZA1JD00G and ZA1JA2A have also added to v2.04 XML folder. Launch control and Flat-Foot Shift is not implemented yet.
Edit (8/20/14):
v2.05b
-Add tuned ROM support for ZA1JA01N (EH 6MT) and ZA1JA03N (EH 6MT) Calibration IDs.
-XML files for ZA1JA01N and ZA1JA03N have also added to v2.04 XML folder. Launch control and Flat-Foot Shift is not implemented yet.
The Following 45 Users Say Thank You to Shiv@Openflash For This Useful Post:
1quickchic (04-07-2016), 200hp/tonne (07-27-2014), Aerok (07-25-2014), Apoc (07-25-2014), BolognaWalrus (07-25-2014), Boofneenee (07-25-2014), cameronjones239 (12-25-2014), CamryDS (07-25-2014), chas3wba0 (08-18-2014), DAEMANO (07-25-2014), Danklvr (07-25-2014), edeekeos (07-26-2014), Efferalgan (07-28-2014), evox2frs (07-25-2014), flippy (08-13-2014), FRSToyota86 (09-27-2015), fstlane (07-25-2014), garfull (07-25-2014), G_Rossney (08-13-2017), Hagbard (07-25-2014), jdcorbitt3 (07-25-2014), JPxM0Dz (07-25-2014), lucid215 (07-25-2014), makinen (07-26-2014), mmmcambelsoup (07-25-2014), Nardi330 (07-27-2014), NorCal_Guy (07-26-2014), number1Tango (01-21-2016), phrosty (07-25-2014), ShadowSeraph (07-29-2014), silverbullet (07-26-2014), skye67 (07-25-2014), Sojhinn (07-25-2014), solidONE (07-25-2014), Superhatch (08-13-2014), themajesticone (07-25-2014), tomaszjanczak (07-25-2014), Triumphrider (07-25-2014), vynervt (07-25-2014), Wepeel (07-28-2014), WillRacer1jz (09-24-2015), WRB5titch (07-28-2014), xxBrun0xx (07-26-2014), YMAA (07-25-2014), ZZT86 (07-28-2014)
Old 07-25-2014, 03:22 PM   #2
tomaszjanczak
Drives: Silver Subaru BRZ
The download link from your website doesn't work for me, it gives me a 404: Page Not Found error.
tomaszjanczak is offline   Reply With Quote
Old 07-25-2014, 03:30 PM   #3
Shiv@Openflash
Drives: 2013 FRS
Oops.. sorry. Try again
http://openflashtablet.com/page33/pr...ads/index.html
Old 07-25-2014, 03:31 PM   #4
tomaszjanczak
Originally Posted by Shiv@Openflash View Post
Works perfectly now, thanks! Can't wait to try it out!
Old 07-25-2014, 03:33 PM   #5
JPxM0Dz
F Z1LLA
JPxM0Dz's Avatar
Drives: Lexus IS-F Series 2
Thanks for this
2URGSE
JPxM0Dz is offline   Reply With Quote
Old 07-25-2014, 03:42 PM   #6
phrosty
Where do you see the most gain with these? Does the open-loop fueling table finally match actual AFRs?
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-25-2014, 03:54 PM   #7
mmmcambelsoup
mmmcambelsoup's Avatar
Drives: FR-S 10 series
For some reason, I am unable to extract the files due to some encryption error.. @Shiv@Openflash
mmmcambelsoup is offline   Reply With Quote
Old 07-25-2014, 04:19 PM   #8
Malt
Drives: 2015 WRX
Just hit yes and it will extract. That message is from shiv using disk encryption on his mac. You can safely ignore it.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Old 07-25-2014, 04:19 PM   #9
wparsons
wparsons's Avatar
2.0 is definitely worth upgrading to. I've had the privilege of being part of the early beta test, and it runs great.
I just downloaded the new files from the link Shiv posted, they extract just fine for me.
flickr
Old 07-25-2014, 04:28 PM   #10
mmmcambelsoup
That sucks, I hit yes and it ends up with another pop up "A problem is preventing this forlder form being encrypted" and just keeps erroring out.
**EDIT**
So I hit yes several times and then it worked! thanks.
Old 07-25-2014, 04:30 PM   #11
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Not seeing FFS/LC on the new 2.0 B01C with the new RR Def file.
Want to disable them in the rom now that they are finally avail...
edit : v2.0 UEL 91Oct
anyone else notice the same, or am i blind?
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 07-25-2014, 04:32 PM   #12
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Im getting these chopped off file extensions after I uploaded the new maps to my OFT.... nothing to worry about?
Cockatoo is offline   Reply With Quote
Old 07-25-2014, 04:34 PM   #13
Malt
Drives: 2015 WRX
**EDIT**
So I hit yes several times and then clicked skip several times.. it ended up downloading. Is there stage 2 'UEL'? I only see 'EL' stage 2.
You need to hit yes for them all. It's saying that for every directory. Better yet, hit apply to all then hit yes.
Sent from my SCH-R970C using Tapatalk
Old 07-25-2014, 04:35 PM   #14
Malt
Drives: 2015 WRX
Looks like a graphical limitation of the number of characters displayed.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
