Old 09-16-2017, 01:30 PM   #337
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by Breadman View Post
here you go
That's all Shiv had to do was post it here and on his website. Would save him from getting 100's of emails a day. Time that could be spent on perfecting the tune
SuperTom is offline   Reply With Quote
Old 09-16-2017, 02:02 PM   #338
Teseo
Drives: frs
Or he is on a Hospital or he will ditch the platform. I want a review like he did on v2, dynos comparisons and all that kind of crap.
The Following User Says Thank You to Teseo For This Useful Post:
nikitopo (09-17-2017)
Old 09-16-2017, 04:12 PM   #339
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
its actually looking better now but still slightly rich. im going to drive out to a friends so im going to try some highway pulls. here were my last 3 logs http://datazap.me/u/gnuworldorder/lo...5?log=0&data=1
Old 09-16-2017, 06:34 PM   #340
steve99
Drives: FT86
ok here is open loop fuel maps and WOT fuel map you cannot see in the tune
so it lloks like its doing what shiv intended ie its arround 11.7 full load high rpm.
You likely going to have to ignore the logged parameters "commanded AFR" as i looks like its not logging the true commanded afr.
also IAM from memory as it was logging a zero and incorrect
Breadman (09-17-2017)
Old 09-16-2017, 06:38 PM   #341
steve99
Drives: FT86
Stock K00C fuel mapping for comparision
Old 09-16-2017, 08:31 PM   #342
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
OFT has never once logged true commanded afr, you know this already steve.
Old 09-16-2017, 08:35 PM   #343
steve99
Drives: FT86
haha, it was a reasonable approximation on older roms but on the 17 it looks like its logging the WOT fuel table only
Old 09-17-2017, 05:33 AM   #344
pym19109
WRBLUE BRZ
pym19109's Avatar
Drives: 2016 Subaru BRZ
Is it possible to have a tactrix tutorial for beginner ?
Only one reason I bought OFT because there are many guide about OFT.
pym19109 is offline   Reply With Quote
Old 09-17-2017, 05:54 AM   #345
Wayno
Wayno's Avatar
- Install
- Select BRZ
- Add or copy definition if required
- Always select yes to correct checksums
No more easy or complicated than OFT, just different.
There's very little point unless you have the logger definitions for your calibration though, or you simply flash and log EU rom.
The Following User Says Thank You to Wayno For This Useful Post:
pym19109 (09-17-2017)
Old 09-17-2017, 06:03 AM   #346
pym19109
WRBLUE BRZ
pym19109's Avatar
- Install
- Select BRZ
I think I wasted some money
Old 09-17-2017, 10:49 AM   #347
Wayno
Wayno's Avatar
Why? OFT is the only one you can have realtime display and log simultaneously. One isn't better than the other, they just have different uses.
The Following 2 Users Say Thank You to Wayno For This Useful Post:
nunonuna (09-17-2017), pym19109 (09-17-2017)
Old 09-17-2017, 11:09 AM   #348
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Exactly
The Following User Says Thank You to nikitopo For This Useful Post:
Old 09-17-2017, 12:57 PM   #349
Breadman
Breadman's Avatar
sounds good thanks. logging is kind of weird on the 17 it looks like. for example maf voltage is just a constant 0...
Old 09-17-2017, 05:13 PM   #350
nunonuna
nunonuna's Avatar
Agreed.
Also, It is so funny to see many of my local friends who have Ecutek in there 86 saying Ecutek is much better than OFT while none of them do even a single data logging.
나의 SM-N950U 의 Tapatalk에서 보냄
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
Teseo (09-17-2017)
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 09:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 05:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 10:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
