Old 03-15-2016, 06:12 PM   #15
RacerX661
Drives: 13' FR-S
Originally Posted by 0351USMC View Post
Shiv I pm'd you this question but not sure if you got it or not. I wrecked my car and don't have access to it to unmarry my OFT. Is sending the OFT back to you guys the only option I have?
Did you ever get this worked out??
RacerX661 is offline   Reply With Quote
Old 03-16-2016, 02:21 AM   #16
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Originally Posted by grichardt View Post
Old thread revival.....did you ever get this worked out
Yes I did. Shiv came thru for me.
0351USMC is offline   Reply With Quote
Old 03-20-2016, 07:39 AM   #17
RD1428
RD1428's Avatar
Drives: 2013 Scion FRS
@Shiv@Openflash i sold my oft to someone and they are trying to use it. I Reflashed my car( which I got rid of so i know the stock file is in there since it went from turbo to stock away without issues.) so the stock file is on there. I pressed the erase button and everything went grayed out. It's still not letting the other person use the oft. Is there anything else that can be done so that he can use it?
RD1428 is offline   Reply With Quote
Old 03-20-2016, 07:43 AM   #18
steve99
Drives: FT86
did you have internet connection when you erased oft ? you need to use erase function in openflash manager software, not just erase tune slots.
look at read button it should be active if its been erased correctly.
also look at tune slots should show all blank even original file.
get the guy to connect it to openflash manager with internet connection and try erase again
Old 09-09-2017, 11:36 AM   #19
Cycletech
Drives: 2014 Scion FRS Monogram
Just Received My OFT yesterday Brand new from FT86 Speed factory. During installation after it reads my ECU it prompts me to turn off ignition and unplug the OFT?? The Icons for READ and WRITE go Dark(disabled)? I used manager to erase the file and tried again with the same outcome? Anyone know what the hell is wrong?? Thanks
Cycletech is offline   Reply With Quote
Old 09-09-2017, 01:48 PM   #20
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
http://www.openflashtablet.com/install/
If you haven't watched the video, watch it and tell us where it all goes wrong
Old 09-09-2017, 02:25 PM   #21
Cycletech
It go's wrong after it saves my ECU info. I plugged in unit, turned ignition on(second stage with all dash lights on) Push read, go's through both read and downloading. Then instead of saying read complete turn off ignition it says turn off ignition and disconnect OFT. At this point I can no longer read or write.
Old 09-09-2017, 04:53 PM   #22
Spuds
The Dictater
Spuds's Avatar
Did you turn off the ignition, unplug the oft, then plug it in again to see if the write options are available? The vid was probably made with an early version of the software, and some of the GUIs and prompts may have changed. I think when I first set mine up it was a bit different.
Also, you said you deleted the file with the manager, but as I understand it, you should not be able to delete the original that it downloaded from the ECU. That gets stored permanently until you unmarry the oft from the car.
Old 09-09-2017, 05:04 PM   #23
Cycletech
I tried doing what it said with no luck. Once I erased it on manager it gave me back the Read icon and was able to perform the Read process over again with the same end result! Its really pissing me off to be honest! I'm a powersports Tech and run my own Small engine performance machine shop. Ive worked with DynoJet, Bazzaz and other ECU tuning companies so Im not unfamiliar with this type of stuff but this Annoying. Ive had to Reflash ECU's for stuff before but not a open flash platform like this.
Old 09-09-2017, 05:19 PM   #24
Spuds
The Dictater
Spuds's Avatar
Huh, that's interesting. So what cal id is it saying your ECU is at? Also, this ECU has the stock tune on it right?
Old 09-09-2017, 06:03 PM   #25
Cycletech
Cal# ZA1JB01C
The car was stock completely when I got it so I dont believe it was tuned.
Old 09-09-2017, 06:40 PM   #26
Spuds
The Dictater
Spuds's Avatar
Cal# ZA1JB01C
Hmm. I'm stumped at this point. There's a couple folks on here who have done a lot more with the oft than I have, so hopefully they will chime in. You can also call Openflash and they should be able to help you out.
Sorry I'm not much help. Good luck.
Old 09-09-2017, 06:49 PM   #27
Cycletech
I appreciate you trying to help!
I sent Shiv a message earlier today on here and also left a email at Openflash. Now its a waiting game for me! Really sucks!!
Old 09-10-2017, 01:29 AM   #28
steve99
Drives: FT86
It probavly been tuned prevoiusly with ecutek or has a calid altered rom
Post up you rom ill have a look
In the meantime just dowload the tunes from openflash site upload to tavlet with openflashmanager try the b01c tunes, will likely work.
Oft will only auto generatectunes if your rom was 100% stock
Spuds (09-10-2017)
Tuning for 86 in SA CPI - Open Flash units Fuzz AFRICA 29 03-15-2014 12:08 AM
Open Flash Tablet Manager Software (problem after internet update) SloS14 Software Tuning 6 10-31-2013 03:33 PM
Open Flash Tablet Question davidchoi Software Tuning 7 10-29-2013 01:58 PM
Torque App & Open Flash Tablet Hanni_0176 Software Tuning 10 10-22-2013 04:53 PM
Open Flash v FA20/Visconti etc,? cuddefred Software Tuning 15 10-09-2013 01:27 AM
