Old 01-01-2014, 09:41 PM   #1
Sgt.Beardface
OMOH O2
Drives: Midget Women Crazy!!
Open flash erasing/unmarry
Anybody have any advice for how to delete the information off this thing and unmarry it from my car? I am confused as hell. The erase info tab is black out and I can't use it. I got rid of the mod file but the rest of the info laughs at my stupid clicks on the erase data link. Any help would be hella appreciated.
-Chuck
You don't need a parachute to skydive; you only need a parachute to skydive twice.
I calls her Mrs. Lohan LIKE A SIR!!
Sgt.Beardface is offline   Reply With Quote
Old 01-01-2014, 09:45 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
-Chuck
All you'll need to do is write the original file back into your ECU. At that point, the Erase function will be available just as long as you have a wifi connection on your laptop.
Shiv
Old 01-01-2014, 09:55 PM   #3
Sgt.Beardface
OMOH O2
Wow. That's awesome thank you. It finally let me use that button
Old 05-05-2014, 09:32 AM   #4
PoorMansRacing
Anorexic
PoorMansRacing's Avatar
Drives: 2003 Honda S2000 Suzuka Blue
Shiv
Hi Shiv, is it possible to unmarry the OFT without reflashing back to the original file? At the last minute, I had a tuner tune my car using Ecutek, so I didn't have my OFT with me to flash back to stock beforehand. Since the tuner is located in another state, I won't be able to reflash and flash back to his map.
Is there a workaround?
PoorMansRacing is offline   Reply With Quote
Old 05-05-2014, 07:56 PM   #5
steve99
Hmmmm looks like you might have snookered yourself there.
The whole idea of the marry/de-marry is to stop the device being used on multiple cars at once, you will most likely have to ship it back to Vishnu to get them to unmarry it for you. Else your going to loose your ecuteck tune and the licence info embedded in the ecutek ROM. The Ecutek tune might be locked as well so you might not be able to write anyway.
Old 07-21-2014, 09:11 AM   #6
carlitosway6891
Drives: white out project fr-s
so i have the original file flashed back on my car but im still not able to erase the data/ unmarry it through the software.....help??
carlitosway6891 is offline   Reply With Quote
Old 07-21-2014, 11:13 AM   #7
Shiv@Openflash
Drives: 2013 FRS
There is a software limit to how many times you can erase the OFT. In the older units, it is twice. In the newer units, it is 5 times. If you reach that limit, the Erase function will be greyed out/unselectable. If that is the case, just email us the OFT's serial number (you can see it in the top window of the OF Manager screen when the OFT is connected). We can then then reset the limit remotely so that you will be able to erase the data the next morning.
Of course, make sure you have a WIFI connection when trying to use the Erase function
Old 08-04-2014, 05:34 PM   #8
Mooseknuckle44
Mooseknuckle44's Avatar
So l tried using my recently purchased used OFT in my car. Step one-plug into OBD2 connector, check.
Turn on ignition to the ON position, check
That's as far as l can go. Looks like it's still married to the orevious owners car but he says he unmarried it.
It wont allow me to select vehicle after l press "Tuning"
Takes me directly to the Read/Write/
Any help will be ridiculously appreciated. Please.
2013 FRS-Asphalt-M6-Invidia N1, K&N drop in, plasti dipped emblems, debadged FRS, Spyder II tails, 5000K Bi-xenon HID's, red demon eyes, Quad halo's, switchbacks w/Tapturn mod,Grimmspeed hood struts, led everything exterior, H&R 25mmF/15mmR spacers, Sportlines, SPC LCA's..(FUN car)
Mooseknuckle44 is offline   Reply With Quote
Old 08-04-2014, 06:02 PM   #9
Shiv@Openflash
Drives: 2013 FRS
I would contact the buyer and let me know that your OFT is still installed in his car. Have you tried going to the Erase Data menu to erase it? It's possible he just forgot that step.
Old 08-04-2014, 06:03 PM   #10
Mooseknuckle44
I was going to try that, but l don't really speak computer. Lol. Was afraid l'd screw something up and have to send it to you guys. Trying that now. Thanks for the quick response.
Old 08-04-2014, 06:18 PM   #11
Mooseknuckle44
That appears to have worked. Thank you!!
Old 08-04-2014, 07:23 PM   #12
Shiv@Openflash
Drives: 2013 FRS
Old 03-16-2015, 01:35 PM   #13
0351USMC
0351USMC's Avatar
Drives: 2014 FRS JRSC'd
Shiv I pm'd you this question but not sure if you got it or not. I wrecked my car and don't have access to it to unmarry my OFT. Is sending the OFT back to you guys the only option I have?
0351USMC is offline   Reply With Quote
Old 05-05-2015, 09:28 PM   #14
grichardt
grichardt's Avatar
Old thread revival.....did you ever get this worked out
grichardt is offline   Reply With Quote
Tuning for 86 in SA CPI - Open Flash units Fuzz AFRICA 29 03-15-2014 12:08 AM
Open Flash Tablet Manager Software (problem after internet update) SloS14 Software Tuning 6 10-31-2013 03:33 PM
Open Flash Tablet Question davidchoi Software Tuning 7 10-29-2013 01:58 PM
Torque App & Open Flash Tablet Hanni_0176 Software Tuning 10 10-22-2013 04:53 PM
Open Flash v FA20/Visconti etc,? cuddefred Software Tuning 15 10-09-2013 01:27 AM
