Old 10-21-2013, 07:44 AM   #1
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
Torque App & Open Flash Tablet
Hey guys, I had a quick question that I didn't find in any searches. I plan on getting an Open Flash Tablet sometime this winter, or even as early as next month.
I was also interested in checking out my oil temps and other stuff, and was considering purchasing a Bluetooth OBD Scanner + Torque Pro.
My question is... does the OFT pretty much do everything that the Torque App can? If so, I'll just skip it. If not, can anyone list some of the stuff that the Torque App can do that the OFT cannot?
Just trying to determine if I should get the Torque App now and the OFT later, or if I should just wait and get the OFT only.
Any and all help is appreciated.
Hanni_0176 is offline   Reply With Quote
Old 10-21-2013, 08:35 AM   #2
fstlane
fstlane's Avatar
Drives: BRZ Limited
I have both and I would definitely spend $20 on the Torque app and a cheap Bluetooth adapter. There really are two completely different products and there is some cool stuff you can do with the Torque app. There are different plugings to overlay data over video, knock monitors and you can configure your own layout. Here's one that I have been running.
fstlane is offline   Reply With Quote
Old 10-21-2013, 09:16 AM   #3
cnk
Drives: '13 DGM BRZ Limited
It's not something anyone can compare right now except maybe Shiv from Vishnu because no one has seen what the logging features will be like on the OFT yet. Since both pull their data from the OBDII port, they should be capable of getting the same information. It then comes down to which interface you like better.
cnk is offline   Reply With Quote
Old 10-21-2013, 09:20 AM   #4
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
@fstlane has anyone figured out how to monitor 'knock correction CA" in the real time logging screen without switching to the knock add on? I haven't messed with configuring your own layout. Can you give me a little more info on how you did this?
I too like the Torque app. I have EcuTek but the interface that the Torque app gives you is fantastic. You don't the refresh rate that EcuTek will give you but it is also half the hassle. No cord, and you have real time data in an easy to read display.
calispec is offline   Reply With Quote
Old 10-21-2013, 10:37 AM   #5
fstlane
fstlane's Avatar
Drives: BRZ Limited
I've never seen the "knock correction CA" parameter in available sensors but hopefully someone can find the settings to add a custom PID for it. I'm running the RacrMeter plugin in the above screenshot.
Old 10-21-2013, 02:30 PM   #6
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
you can look at the screen captures for the logging feature for the oft on their other cars. i have both and will use the oft for data logging and the torque app when i want to see fancier gauges. for 20 bucks the app and connector was a no brainer for me and the oft is the best upgrade ive done so far.
garfull is offline   Reply With Quote
Old 10-22-2013, 12:08 AM   #7
glorydays
Remember me?
glorydays's Avatar
Drives: BRZ Series.Blue
im using the app right now and honestly i wouldnt trust it as a data logging platform. A lot of the info seems inaccurate and more of a novelty. It said my peak hp number is 219whp . it does vocally notify you when the car has reached normal operating temp though which is pretty useful.
glorydays is offline   Reply With Quote
Old 10-22-2013, 12:25 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
Water and oil read out is worth the price in itself IMO
Old 10-22-2013, 12:39 AM   #9
Hanni_0176
Hanni_0176's Avatar
That's pretty much the whole reason I wanted to get it. I've read a bunch about the oil temps, and it appears that the operating temps of the oil are roughly 185* F, which takes longer to reach than the water temps of 195* F. It sucks seeing my temp gauge in the car read warm (coolant), but not knowing when the oil temps are warm enough to be able to rev past 3k rpm's.
I figured the OFT would do the same thing, but I also saw that Torque logged 0-60 and 1/4 mile times, etc, which seemed useful. The fact that it actually announces when the oil reaches operating temps just sold me on it though. Thanks for that.
Old 10-22-2013, 04:03 PM   #10
jamesm
if you're going to use torque, spend the money on a decent elm327. the cheap chinese knockoffs are so slow as to be marginally useful for monitoring, and completely useless for any sort of logging. they're not cheap, but you get what you pay for.
Old 10-22-2013, 04:53 PM   #11
topazsparrow
Drives: slow
If the HP calculations were any more than an extremely rough estimate based on the GVW you entered and the accelerometer readings, we wouldn't need Dyno's worth thousands of dollars.
The other information regarding what the ECU sees (temps, o2, pressure, timing etc) will be as accurate as the sensor sending it.
topazsparrow is offline   Reply With Quote
Open Flash Tablet Question davidchoi Software Tuning 7 10-29-2013 01:58 PM
Open Flash v FA20/Visconti etc,? cuddefred Software Tuning 15 10-09-2013 01:27 AM
7.0 Tablet w/ Torque App Thatruth2001 Northwest 26 11-21-2012 11:53 AM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
