Old 07-24-2017, 02:18 AM   #15
Originally Posted by allowe View Post
See this is what I'm wondering. I've heard of people complaining about our transmissions a lot. what's the point of getting a new one swapped in if they all feel like that.
Some say an oil change with motul 300 makes a difference.
I'm thinking that some of you folks should trade in your cars for a car with an automatic transmission ......
Old 07-24-2017, 02:22 AM   #16
allowe
allowe's Avatar
allowe is offline   Reply With Quote
The Following 2 Users Say Thank You to allowe For This Useful Post:
Captain Snooze (07-25-2017), humfrz (07-24-2017)
Old 07-24-2017, 02:26 AM   #17
Lust
Drives: 2017 Subaru BRZ
Found the thread:
http://www.ft86club.com/forums/showthread.php?t=31929
Lust is offline   Reply With Quote
The Following User Says Thank You to Lust For This Useful Post:
allowe (07-24-2017)
Old 07-24-2017, 02:34 AM   #18
allowe
allowe's Avatar
Originally Posted by Lust View Post
Wow that was a good read, thank you! It makes sense.
Also did the oil change make any difference at all? Or was it exactly the same?
Old 07-24-2017, 02:45 AM   #19
Lust
I honestly couldn't say. It might have been placebo. I know that my 2017 BRZ trans shifts smoother than my 15 FRS. I'll swap to Motul Gear 300 soon and report back.
Old 07-24-2017, 01:18 PM   #20
Mchilese
Mchilese's Avatar
Drives: '14 BRZ Limited
The way I look at it is the transmission isn't "supposed" to grind. If it is, that's a problem. There's a difference between notchy and grinding, too. If it's grinding you should get it looked at.
My new transmission is what I would call "notchy" but definitely isn't grinding anymore.
Sent from my Moto G (4) using Tapatalk
2014 BRZ
Mishimoto intake tube/TSW Nurburgring 18x8/Firestone Firehawk Indy500s/PLM muffler delete/JDL catted UEL headers
Mchilese is offline   Reply With Quote
Old 07-24-2017, 09:49 PM   #21
takethecake
I have a 2013 that's out of warranty now, and within the last 6 months or so, I've started noticing it will slip out of 5th gear into neutral every once in a while. I installed the perrin bushing/whiteline positive shift kit/mtec springs mods about a month ago, and since then the problem is much better, although it has happened once since then. I replaced the tranny fluid at ~35k miles with motul 300 too. Probably bad synchro, sigh..guess there's not too much I can do about it now, other than replace the fluid again. (I'm around 72k miles now)
takethecake is offline   Reply With Quote
Old 07-25-2017, 03:25 AM   #22
Lust
You realize it's suggested to change tranny/diff fluid every 30k sometimes earlier right?
Old 07-26-2017, 11:04 AM   #23
takethecake
I'm pretty sure the maintenance schedule in my user manual just said to "inspect" every 30k miles, but I guess I haven't been doing that either - might as well replace it if you're going to the trouble to inspect (our tranny's don't have dipsticks do they?)
Guess I know what I'm doing this weekend - probably going to try Pentosin MTF2 this time around just for curiousity's sake if I can find it/get it and crush washers before saturday.
Thanks for the tip!
The Following User Says Thank You to takethecake For This Useful Post:
Lust (07-26-2017)
Old 07-26-2017, 03:53 PM   #24
Lust
Thanks for the tip!
It all depends on how you drive. Someone who regularly tracks the car and drives it hard may change fluid every 5k. If you're driving it as a daily I'd recommend changing it every 30k. Preventative maintenance is key. Your issue may have stemmed from not changing the fluid soon enough
4th gear grind dallenj Engine, Exhaust, Transmission 15 06-03-2016 05:04 PM
5th and 6th gear grind... Basket Case Engine, Exhaust, Transmission 7 02-11-2015 09:53 PM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 06:47 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 05:02 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 08:37 PM
