Old 01-29-2015, 10:43 AM   #1
Basket Case
Drives: 2013 Raven fr-s
5th and 6th gear grind...
So fairly recently I have noticed that whenever I shift down from 6 the into fifth it will grind pretty badly into gear...I have my foot to the floor with the clutch, and have even tried double clutching and I am getting a grind 95% of yeah time. If I am accelerating quickly and shift from 4th into 5th it will grind as well. I even just a few minutes ago had it grind into 6th as I was accelerating away...
The car has 43,858 miles on it. My understanding is that there is a 60,000 mile power train warranty. What is the likelihood this will be fixed under warranty? It is driving me crazy and absolutely ruins the driving experience when I'm constantly worrying about shifting...also, anyone have any suggestions? I don't think simply changing the fluid is going to fix this.
Basket Case is offline   Reply With Quote
Old 01-29-2015, 10:59 AM   #2
humfrz
You may consider checking the clutch adjustment .....
Maybe bleed the clutch/brake system.
humfrz
Old 01-29-2015, 11:06 AM   #3
Basket Case
If the clutch adjustment was off wouldn't I be grinding in other gears as well? Out of all my cars with a hydronic clutch I don't think I ever once needed to bleed the clutch.
Old 01-29-2015, 11:24 AM   #4
WNDSRFR
Drives: FR-S,GTI
Bring it to the dealer. But first remove any performance mods. I got a new transmission under warranty but I only had like a couple thousand miles.
Had exactly the same problem. Fifth gear grinding going in or out of gear.
Old 01-30-2015, 12:12 PM   #5
Basket Case
sitting at the dealer waiting for them to look at it. Hopefully it just ends with them ordering me a new trans...
Old 01-30-2015, 04:15 PM   #6
Basket Case
Dealership confirmed a bad transmission. Getting a new one installed next week. If anyone is having any major grinding issues take your car in and have them replace the trans!
Old 02-01-2015, 02:09 PM   #7
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Man, sounds like a real basket case
Old 02-11-2015, 08:53 PM   #8
ironsurfer129
Drives: Whiteout FR-S
What would be consider performance mod? I have the shift bushings, exhaust. Are they co sider performance mod?
ironsurfer129 is offline   Reply With Quote
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 05:47 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
