Old 01-16-2015, 06:06 PM   #1
Since885
Grind Into 5th Gear
Has anyone experienced a grind in the transmission when switching from 4th to 5th gear? When im on the highway and switch to 5th gear it never fails to have a grind in the shift.
Since885 is offline   Reply With Quote
Old 01-16-2015, 06:15 PM   #2
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Mine shifts like butter.
hmong337 is offline   Reply With Quote
Old 01-16-2015, 09:03 PM   #3
PandaBRZ
PandaBRZ's Avatar
Drives: SWP BRZ
This happened to me for a while but not consistently. Switched to Motul Gear 300 and it went away.
Read my writing about the BRZ on my website.
PandaBRZ is offline   Reply With Quote
Old 01-16-2015, 09:43 PM   #4
rburrow87
rburrow87's Avatar
Drives: (SOLD) '13 BRZ Ltd SSM / '91 Miata
I've had it grind from 6 to 5 while cold. It's also a bit stiff in general when it's cold. Warmed up, it's all good. This is even after switching to Motul Gear 300.
rburrow87 is offline   Reply With Quote
Old 01-16-2015, 10:01 PM   #5
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Factory fill, lots of track hours, no issues when warm.
Decay107 is offline   Reply With Quote
Old 01-18-2015, 05:31 PM   #6
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Grind Into 5th Gear
Use to happen a lot till I changed out engine oil... I don't know how don't ask me. lol
But after that it happened once at 5th on highway after a day of track. I think stock trans fluid is passable but can use something better for sure.
Old 01-18-2015, 05:37 PM   #7
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Mine does it from time to time. Regardless when it is warmed up or not.
Muaddib is offline   Reply With Quote
Old 01-18-2015, 05:45 PM   #8
Since885
What oil did you switch to?
Old 01-18-2015, 05:47 PM   #9
Since885
Yeah even after a few hours of driving if I hit the highway I still get the grind.
4th gear grind aaguirre123 Engine, Exhaust, Transmission 8 08-03-2015 04:58 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
Gear grind downshifting from 6th to 5th JarredH Issues | Warranty | Recalls / TSB 6 03-21-2014 03:52 AM
4th gear grind Moetivegt86 Issues | Warranty | Recalls / TSB 10 03-07-2014 11:50 AM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
