Old 07-23-2017, 05:09 PM   #1
allowe
allowe's Avatar
4th to 5th gear grind.
Recently, I've been noticing that when shifting from 4th to 5th, it makes a crunch like feeling. I've been noticing this happening at least twice a week. I feel like it's starting to happen with 2nd and 3rd too but it's not nearly as bad.
It doesn't happen after that though for another couple of days and I drive a lot. I'm still under warranty which is why I'm bringing this up, otherwise I would've just forgot about it till the tranny died then paid the 500 bucks and did it myself.
Anyone else experiencing this? I was thinking an oil change might make a difference but, I don't wana touch it so they don't say "oh you voided the warranty.
Any similar experiences?
allowe is offline   Reply With Quote
Old 07-23-2017, 06:25 PM   #2
GoZ21
GoZ21's Avatar
Drives: 2013 Asphalt Frs
Crunchy and grinding 5th is very common, something i am dealing with personally at the moment, its most likely bad synchros, i just recently got my car used so im not under warranty so im curious to see what some other people have done to remedy this, im sure there is a previous thread regarding this and if thats the case i hope someone could post a link to that here
GoZ21 is offline   Reply With Quote
Old 07-23-2017, 07:38 PM   #3
allowe
allowe's Avatar
Wow thanks for your post! I bought mine used too but from a Toyota dealership and it came with the remaining balance. I might take it to the dealer and see what's up but it's common? I need to research on that
Old 07-23-2017, 07:53 PM   #4
Terruko
Terruko's Avatar
Same with mine, and I'm still under warranty. I was suppose to take it to the dealership on friday but some things came up and couldn't make it. The problem with mine is that it doesn't happen all the time and the technician couldn't replicate the problem (The first time I took it)
Terruko is offline   Reply With Quote
Old 07-23-2017, 08:30 PM   #5
GoZ21
GoZ21's Avatar
Yes, very common problem in early production lf the car, like i said before it is most likely because of bad synchros. Best way to tell if that is the issue is to give the gas a little blip while your shifting into that 5th gear almost like rev matching a downshift, if the grind or crunch is somewhat alleviated you can almost be sure that the synchros are the culprit. Toyota in the beginning was ripping the gearboxes out of the 13 model and sending them out for evaluation when this was becoming a problem so take it into the dealer for sure
Old 07-23-2017, 08:35 PM   #6
allowe
allowe's Avatar
Hey... I've got a header on my car and a tune. Should I tune it back to stock and rip out the header before going in?
Old 07-23-2017, 08:41 PM   #7
Teseo
Drives: frs
Change transmission fluid, make wonders on that simple maintenance
Old 07-23-2017, 11:44 PM   #8
Mchilese
Mchilese's Avatar
Drives: '14 BRZ Limited
Got mine used too, had bad synchros in my transmission. Took it in and got it replaced under warranty. Took a while to get the unit in from Japan.
Sent from my Moto G (4) using Tapatalk
2014 BRZ
Mishimoto intake tube/TSW Nurburgring 18x8/Firestone Firehawk Indy500s/PLM muffler delete/JDL catted UEL headers
Mchilese is offline   Reply With Quote
Old 07-23-2017, 11:45 PM   #9
allowe
allowe's Avatar
Did they give u hassle? What did u do to convince them ?
Old 07-24-2017, 12:05 AM   #10
Mchilese
Mchilese's Avatar
...I told them my transmission was grinding between gears. They took me with them on a test drive, confirmed what was going on. Then they ordered a new transmission.
Transmission work is standard drivetrain warranty thing.
2014 BRZ
Old 07-24-2017, 12:24 AM   #11
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Same with my 4th to 5th if I hurry. Usually I just ease it in (that's what she said)
and there is no graunch.
Old 07-24-2017, 12:51 AM   #12
Lust
Drives: 2017 Subaru BRZ
I've had that feeling in my old 2015 FRS and my brand new 2017 BRZ.
Lust is offline   Reply With Quote
Old 07-24-2017, 12:55 AM   #13
allowe
allowe's Avatar
See this is what I'm wondering. I've heard of people complaining about our transmissions a lot. what's the point of getting a new one swapped in if they all feel like that.
Some say an oil change with motul 300 makes a difference.
Old 07-24-2017, 01:15 AM   #14
Lust
Just learn to live with it. Even after I had the Motul fluid swap on my 15 FRS, it still had the 4-5 grind issue. These AISIN transmissions are intended to have very tight tolerances. There's a thread on it somewhere I'll link it once I find it.
4th gear grind dallenj Engine, Exhaust, Transmission 15 06-03-2016 04:04 PM
5th and 6th gear grind... Basket Case Engine, Exhaust, Transmission 7 02-11-2015 08:53 PM
Grind Into 5th Gear Since885 Engine, Exhaust, Transmission 8 01-18-2015 05:47 PM
2nd gear grind (yup another one) SmartedPanda Issues | Warranty | Recalls / TSB 17 09-10-2014 04:02 PM
3rd gear grind Mo707 Scion FR-S / Toyota 86 GT86 General Forum 18 07-29-2012 07:37 PM
