Drives: 2013 Scion FRS & 2022 GR86
Vibration/Crunch noise on wheels or suspension area
Hey y'all,
It's been going in for quiet awhile, but I never really worried about it till now. So when I brake hard, I can hear vibration noises in my wheels/rotors area. I can mostly hear it in the front, barely in the back. However, as I continue driving, the sound continue will continue for about a minute after braking. Do you think it'd be the rotors? I also have the Tein Flex Z coil overs, but I don't think that'd be the cause... 2013 Scion FRS @Exrald.frs
2013 Scion FRS 2022 Toyota GR86 |
#2 |
If the vibration only happened when the brakes are applied, I would suspect that your car has at least one warped rotor.
Do you track your car .... ?? Do you go down long, steep hills often ... ?? humfrz |
#3 | |
#4 | |
You may wish to take your car into the dealer or a brake shop and have them check out/replace the rotors. humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Exrald (07-03-2017) |
#5 |
Drives: 2014 Scion FR-S
Do you hear only like a metal scratching noise? or do you hear cricket noises while you're driving too?
| The Following User Says Thank You to Twitchy313 For This Useful Post: | Exrald (07-03-2017) |
#6 | |
#7 |
I ask because I heard cricket noises coming from the tire area, I still have stock coil overs but I can't say thats the problem. I have some scratching noises too and I changed my rotors and break pads. So far it has seemed to take care of that problem, but I still hear some noises.
#8 | |
![]() humfrz |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | Exrald (07-03-2017), Twitchy313 (07-03-2017) |
#10 |
| Diff vibration/noise on decel | Im_SPEED | Engine, Exhaust, Transmission | 9 | 01-28-2017 10:18 PM |
| Crunch noise? | winsometang | Issues | Warranty | Recalls / TSB | 9 | 12-02-2014 02:38 PM |
| trd quick shifter ? vibration noise | Pcharliep04 | Issues | Warranty | Recalls / TSB | 5 | 08-01-2014 03:42 PM |
| Vibration/Noise near instrument cluster? | nktech | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-28-2014 09:42 AM |
| Vibration/Noise when clutch is depressed | Ravenlokk | Issues | Warranty | Recalls / TSB | 17 | 12-02-2013 11:15 AM |
