Old 07-02-2017, 09:27 PM   #1
wrb
frank
wrb's Avatar
Drives: Subaru BRZ WRB
Exclamation 2013 BRZ - Having problem with high beam
Hello,
My 2013 BRZ's left headlight high beam stopped working while ago. I checked the fuse first, and couldn't find any fault. I replaced them anyways but that didn't fix the problem.
After a while, I finally got myself a replacement bulb set. It still wasn't working after that. I checked fuse again, and nothing wrong.
Am I missing something here? Is there some other fuse I should check other than the ones that are labeled high beam?
My right side headlight high beam is working fine.
2013 SUBARU BRZ WRB LIMITED M/T
Los Angeles, CA
Build Photo Album - http://bit.ly/brz_wrb
SoCal LA 86 Club Member
wrb is offline   Reply With Quote
Old 07-02-2017, 09:36 PM   #2
I took this from an old post.
"At least for the FR-S, I know that there is a relay (white/offwhite box) in the fuse box labeled "DRL" that controls both the high beams as well as DRL function, not sure about the BRZ though because it's headlights are OEM hid and LED boomerang DRL. If that relay were the issue then both headlights wouldn't be able to have DRLs or high beams not one. I suggests pulling or tugging on the wires coming from the pins on the connectors with the high beams on to see if it flashes on that side or something."
That might be worth a try.
HID vs LED Low/High beam along with DLR? xFury Cosmetic Modification (Interior/Exterior/Lighting) 5 12-15-2015 12:15 PM
DRL or high beam or both? jacobzking Cosmetic Modification (Interior/Exterior/Lighting) 5 06-09-2013 04:09 PM
HID and high beam use gatorbushmen Cosmetic Modification (Interior/Exterior/Lighting) 4 04-19-2013 05:56 PM
High beam/LED question Trashed675 Cosmetic Modification (Interior/Exterior/Lighting) 15 01-20-2013 01:46 PM
