Old 06-30-2017, 04:06 PM   #1
drz400dude
Oil Pressure
What should our oil pressure be? I have a 13 fr-s. I'm reading from a sandwich plate on the oil filter housing. At idle it drops down to around 15PSI. Is it lower at this location compared to where it's actually running through the engine?
drz400dude is offline   Reply With Quote
Old 06-30-2017, 04:50 PM   #2
Some say that the average engines oil pressure should be about 10 psi for every 1,000 rpms.
So, if your engine is running at about 15 psi and the idle is about 1,000 to 1,500 rpms ....... you're good to go.
drz400dude (06-30-2017), Scrappydoo (06-30-2017)
Old 06-30-2017, 04:56 PM   #3
drz400dude
Hmmm. Ok. Once it completely warmed up it dropped to about 8PSI at idle, but the idle is at about 6-700. So I guess it is alright. Thanks.
The Following User Says Thank You to drz400dude For This Useful Post:
humfrz (06-30-2017)
Old 06-30-2017, 08:22 PM   #4
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Any data from a point other than the front of the block is useless, this is where the manufacturer specifies pressure targets in the manual.
Targets at this point are as follows
At an oil temp of 80*c
greater than 7.3psi during idle
greater than 73psi at 6000rpm
Decay107 is offline   Reply With Quote
The Following 2 Users Say Thank You to Decay107 For This Useful Post:
drz400dude (08-20-2017), Prax (04-30-2019)
Old 06-30-2017, 09:21 PM   #5
drz400dude
Originally Posted by Decay107 View Post
Any data from a point other than the front of the block is useless, this is where the OEM specifies pressure targets in the manual.
I see. From reading some other posts, it looks like you can remove the OEM pressure sensor and replace it with the new gauge sensor without it throwing any CEL codes? Is this true?
Old 06-30-2017, 09:30 PM   #6
Decay107
Decay107's Avatar
Correct, I have been running with no pressure switch for years now.
Also nice choice in bike , got a 400s to SM converted bike in the collection, so fun
Old 06-30-2017, 09:38 PM   #7
You can. That's the preferred place to measure it, just downstream of the filter...
...just barely upstream of the forward main oil galley plug.
Engineers, SMH
e1_griego (06-30-2017)
Old 06-30-2017, 09:47 PM   #8
Decay107
Decay107's Avatar
Engineers, SMH
Whatever helps you sleep at night bro
The Following User Says Thank You to Decay107 For This Useful Post:
Ultramaroon (06-30-2017)
Old 06-30-2017, 10:08 PM   #9
Decay107 (06-30-2017)
Old 04-30-2019, 10:32 PM   #10
Prax
Drives: 2017 BRZ Inazuma Edition
My top oil galley plug just to the right of the throttle body reads around 15 PSI at idle and around 85 PSI at 6000RPM at 80 degrees right now. 2017 BRZ.
Sent from my Pixel 2 XL using Tapatalk
Prax is offline   Reply With Quote
gauge, oil, oil pressure, pressure
Oil Pressure nearvincent Engine, Exhaust, Transmission 3 04-12-2017 07:46 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
What do you consider low oil pressure? protpibe Engine, Exhaust, Transmission 10 01-14-2014 10:19 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
