Old 04-12-2017, 02:07 AM   #1
nearvincent
Drives: GT86
Smile Oil Pressure
Hey guys
Just did a track day and my oil temps reached 128c (262.4F). I'm planning to get an oil cooler but wouldn't that drop my oil pressure even more? if so, would i have to use thicker oil to correct the problem? I'm currently using 0w20 and N/A
Also would an oil catch can be useful for my N/A car?
Thanks for the help guys.
nearvincent is offline   Reply With Quote
Old 04-12-2017, 04:40 AM   #2
dostoyevsky
Drives: 2017 BRZ
Is 130c high? Mine goes to 125c while daily driving
dostoyevsky is offline   Reply With Quote
Old 04-12-2017, 05:14 AM   #3
steve99
Originally Posted by nearvincent View Post
Hey guys
Would not worry about a xatch can on an NA car mainly for boosted guys
If your going to track car in warmer climates like ours a 5w30 or 0w30.
If your going to be a serious track warrior in warm climate then your going to need the full radiator type air to oil coolers avout $800 plus, dont get a crap one get a good brand.
If your only an occasional low level track guys id provsbly go the oem subaru forrester wrx oil cooler the oil to coolant type. Avout 300 and wasy fit, these take about 10 degrees off your oilvtemp but run out of capacity with continuous hard use
Old 04-12-2017, 07:46 AM   #4
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I went to the dealer and ordered the complete forester XT oil cooler. IMO this cooler should of been installed via factory. No oil PSI issues and it holds temps better than nothing. Plus side to using it with a turbo is the car warms up so much faster. Dealer cost with you installing it is around $200-$300
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
catch can, oil pressure, oil temperature, trackday
No a/c but system has pressure ZionsWrath Other Vehicles & General Automotive Discussions 8 06-14-2015 02:43 PM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
What do you consider low oil pressure? protpibe Engine, Exhaust, Transmission 10 01-14-2014 10:19 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
