Old 01-12-2014, 07:16 PM   #1
protpibe
protpibe's Avatar
What do you consider low oil pressure?
I'm in the process of installing an Innovate MTX Oil temp and pressure gauge. It has the ability to setup alarms for what you deem to be low oil pressure, and high oil temperature.
I was just wondering what the general consensus was on what those figures are?
Old 01-12-2014, 07:24 PM   #2
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
In the day, when I was building old school engines, the general rule of thumb was 6 psi per 1000 rpm was a minimum. Don't know how that would apply today.
FRSFirestorm is offline   Reply With Quote
Old 01-12-2014, 07:37 PM   #3
humfrz
As I recall, back in the day ...... 60 psi with thick oil and a cold engine was the norm. 20-30 psi with thinner oil and a warm engine was good.
Now that you know what was "good" from ol FRSFirestorm and humfrz, back in the day, you can sit back and wait for some 21st century information ......
humfrz
Old 01-12-2014, 07:57 PM   #4
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
9 psi
Old 01-12-2014, 08:09 PM   #5
xwd
I'll say 10psi. When the engine is warm my idle pressure is probably around 16psi.
As far as temperature I would say 240. People have certainly seen higher on track days and whatnot but that's what I set mine to.
Old 01-12-2014, 08:54 PM   #6
Ice
Drives: 323
This.
On a street engine, you want about 10psi per 1k rpm.
I.e. at 7500 rpm you want 75 psi.
This goes up if its a race engine etc, I run 11 on my engine
Depends on what oil you use as well (as to what reading you get).
Ice is offline   Reply With Quote
Old 01-12-2014, 09:27 PM   #7
getbent
Drives: 2013 FR-S Blue MT
I believe Subaru specifies 7psi minimum at idle. I typically observe about 1 bar per 1000 rpm.
2013 Scion FR-S | 6MT | UltraMarine
getbent is offline   Reply With Quote
Old 01-12-2014, 10:30 PM   #8
Ice
Drives: 323
Measured from?
Old 01-13-2014, 10:17 PM   #9
getbent
Oil pressure sensor located in oil gallery on the top of the block.
Old 01-14-2014, 01:00 AM   #10
Ice
Drives: 323
Interesting.
Is this the stock location?
Old 01-14-2014, 10:19 PM   #11
getbent
No, the factory oil pressure (switch) and oil temperature (sensor) are located just below the oil filter on the front of the motor.
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 10:09 AM
Tire Pressure Fallen43 CANADA 2 10-12-2013 12:46 PM
Oil Pressure.. too low? Dave-ROR Tracking / Autocross / HPDE / Drifting 65 08-24-2013 12:43 AM
Oil Pressure Specification Captain Snooze Engine, Exhaust, Transmission 0 12-05-2012 06:44 PM
