Old 03-19-2015, 02:55 PM   #1
steveholt
Drives: 2015 BRZ Limited 6MT
best tire pressure gauge (tire pressure question)
hello everyone, i was wondering what tire pressure gauge everyone is using?
what is the best tire pressure gauge available out on the market now? one that possibly doesn't bleed air out too much when trying to engage the valve to get a measurement.
I want to keep the price reasonable but am not opposed to maybe spending around $100(buy once cry once).
also, i've always been told to measure and fill tires when cold or not driven for at least 2 hours.
Our cars being 35 psi all around, would it be ok to let's say fill up early morning when it's colder let's say around 40 degrees? then as the day progresses to the afternoon let's say the temperature increases to 60 or so, would the increase in PSI be ok due to the temperature increase?
I'd imagine car manufacturer's take the above into account and the recommended psi settings are for cold temperature measurements?
steveholt is offline   Reply With Quote
Old 03-19-2015, 02:57 PM   #2
wparsons
wparsons's Avatar
What are you using the car for? If it's just daily driving, you don't need anything fancy at all.
If you're serious into track use, you'll want to monitor hot temperatures RIGHT after coming off the track.
flickr
Old 03-19-2015, 03:22 PM   #3
steveholt
mostly daily driving, i have an older pencil analog type gauge but it is frustrating how much air bleeds out before I can make absolute contact to get a reading, i'm also not entirely sure how accurate it is considering it is an old gauge(5+ years)
occasional track/autocross but i intend on having a dedicated separate set of tires/wheels for those.
Old 03-19-2015, 03:57 PM   #4
wparsons
wparsons's Avatar
Unless air is bleeding out for a couple seconds, you're not losing significant pressure. I would just get an average dial analog gauge. I personally wouldn't want one that doesn't have a button to intentionally bleed off pressure, but that's just preference.
flickr
Old 03-19-2015, 04:03 PM   #5
dp1
driving smoother faster
Drives: Sold
TireRack "The rule of thumb is for every 10° Fahrenheit change in air temperature, your tire's inflation pressure will change by about 1 psi (up with higher temperatures and down with lower)."
You see what happens when your tires get up to about 220F in the summer on track...
dp1 is offline   Reply With Quote
Old 03-19-2015, 04:24 PM   #6
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
I like this one, not too expensive, measures in 0.1 increments, has a bleed valve, and doesn't let lots of air out when using it
http://www.accutiregauge.com/racing-...ressure-gauge/
Scenic Driver is offline   Reply With Quote
Old 03-19-2015, 05:37 PM   #7
wparsons
wparsons's Avatar
Yeah, it tries to burn your hands as you bleed off pressure
flickr
Old 03-19-2015, 08:58 PM   #8
dp1
Drives: Sold
This one has worked well for me (Accutire MS-4355GB Programmable Tire Gauge):
[ame="http://www.amazon.com/Accutire-MS-4355GB-Programmable-Tire-Gauge/dp/B001VJS2FE/ref=pd_sim_auto_5?ie=UTF8&refRID=1RNACSG3QT1SCY4CR 262"]Amazon.com: Accutire MS-4355GB Programmable Tire Gauge: Automotive[/ame]
Quality piece but it will be a little bit less convenient than the one @Scenic Driver suggested, since you need to turn the top so that you can read the display when you push it in, and you have to unplug it after reading to use the bleeder, though you don't have to reset to re-read when you plug it back in.
Old 03-19-2015, 09:03 PM   #9
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
What I use - very easy, precise, and accurate, and shine a light on the face for a few seconds and be able to take readings in total darkness... no batteries required either, have been using it for at least a decade... :
https://www.pegasusautoracing.com/pr....asp?RecID=337
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-19-2015, 09:34 PM   #10
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
good quality ,non racing, sensibly priced and USA made
[ame="http://www.amazon.com/gp/product/B0002SQYTG/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1"]Amazon.com: Milton S921 Dial Tire Gage: Automotive[/ame]
♠♠♠88
Ernie L is offline   Reply With Quote
Old 03-19-2015, 11:11 PM   #11
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
I have one of these, love it.
[ame="http://www.amazon.com/gp/product/B00404WDUC/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1"]hJoes Racing 32307 (0-60) PSI Tire Pressure Gauge[/ame]
JonAvalon is offline   Reply With Quote
Old 03-20-2015, 07:03 PM   #12
brianhj
Drives: 2017 Camaro 1SS
Originally Posted by JonAvalon View Post
I love mine
brianhj is offline   Reply With Quote
Old 03-20-2015, 09:17 PM   #13
Whatabouteggs
[Citation Needed]
Drives: 2014 WR Blue Subaru BRZ Premium
Make sure to get a digital one. We all know how inaccurate analogue tire pressure gauges are.
[ame="https://www.youtube.com/watch?v=miA5qj5ergM"]BMW M4 Crash @ CARS & COFFEE Blackhawk 2015 - YouTube[/ame]
Whatabouteggs is offline   Reply With Quote
Old 03-20-2015, 09:21 PM   #14
wparsons
wparsons's Avatar
I'd take a good quality fluid filled analog one over a digital one every day.
flickr
Tire Pressure Sensors Question NoFlush Mid-Atlantic 5 02-07-2014 06:03 PM
Have a tire pressure gauge you really like? Anthony Tracking / Autocross / HPDE / Drifting 21 09-10-2013 06:09 PM
Question: TPMS Tire-pressure monitoring system installed on aftermarket wheels Figo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 08-05-2013 12:54 PM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 05:47 AM
new rim/tire. question about bolts pressure? and etc WATCHMEHEAL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-25-2013 05:59 PM
