Old 06-30-2017, 12:16 PM   #1
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Vibration/Crunch noise on wheels or suspension area
Hey y'all,
It's been going in for quiet awhile, but I never really worried about it till now. So when I brake hard, I can hear vibration noises in my wheels/rotors area. I can mostly hear it in the front, barely in the back. However, as I continue driving, the sound continue will continue for about a minute after braking. Do you think it'd be the rotors? I also have the Tein Flex Z coil overs, but I don't think that'd be the cause...
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 06-30-2017, 01:12 PM   #2
If the vibration only happened when the brakes are applied, I would suspect that your car has at least one warped rotor.
Do you track your car .... ??
Do you go down long, steep hills often ... ??
Old 06-30-2017, 01:19 PM   #3
Exrald
Exrald's Avatar
I don't track, but I do go through steep hills at fast speeds. And I'm ruthless to my brakes. I'm really hoping it's my rotor...
2013 Scion FRS
2022 Toyota GR86
Old 06-30-2017, 02:08 PM   #4
Well, rotors are relatively inexpensive and relatively easy to replace.
You may wish to take your car into the dealer or a brake shop and have them check out/replace the rotors.
Exrald (07-03-2017)
Old 07-03-2017, 03:10 AM   #5
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Do you hear only like a metal scratching noise? or do you hear cricket noises while you're driving too?
Twitchy313 is offline   Reply With Quote
The Following User Says Thank You to Twitchy313 For This Useful Post:
Exrald (07-03-2017)
Old 07-03-2017, 03:10 AM   #6
Exrald
Exrald's Avatar
Just crunches. No crickets
2013 Scion FRS
2022 Toyota GR86
Old 07-03-2017, 03:12 AM   #7
Twitchy313
Twitchy313's Avatar
I ask because I heard cricket noises coming from the tire area, I still have stock coil overs but I can't say thats the problem. I have some scratching noises too and I changed my rotors and break pads. So far it has seemed to take care of that problem, but I still hear some noises.
Old 07-03-2017, 03:38 AM   #8
They have meds for that .....
Exrald (07-03-2017), Twitchy313 (07-03-2017)
Old 07-03-2017, 03:46 AM   #9
Twitchy313
Twitchy313's Avatar
Please do tell! Lol
Exrald (07-03-2017)
Old 07-03-2017, 01:01 PM   #10
Please do tell! Lol
Well, ya, on the Puyallup Indian reservation, down along River Road, just behind the Pot Shop, an old Indian sells this herb mixture, that makes voices and those sounds .....go away ......
Diff vibration/noise on decel Im_SPEED Engine, Exhaust, Transmission 9 01-28-2017 10:18 PM
Crunch noise? winsometang Issues | Warranty | Recalls / TSB 9 12-02-2014 02:38 PM
trd quick shifter ? vibration noise Pcharliep04 Issues | Warranty | Recalls / TSB 5 08-01-2014 03:42 PM
Vibration/Noise near instrument cluster? nktech Scion FR-S / Toyota 86 GT86 General Forum 11 03-28-2014 09:42 AM
Vibration/Noise when clutch is depressed Ravenlokk Issues | Warranty | Recalls / TSB 17 12-02-2013 11:15 AM
