Old 06-30-2017, 02:22 AM   #85
I blew the joke. I should've referred to heavy water, not deuterium.
Not that it really changes anything but hey, this shit's free.
Ah .... yes, deuterium oxide, D20. Yep, that additional 10% in weight (roughly) just might make a difference ........
Ultramaroon (06-30-2017)
Old 06-30-2017, 02:27 AM   #86
Originally Posted by nikitopo View Post
When I changed my battery to a lighter one, I felt once a very small difference. It was strange, because I wasn't looking to see a difference. I thought that the weight gain was too small (-10lbs). Of course, I might be wrong and it was just my idea.
So, do you notice the difference between a full tank of gas and an almost empty tank of gas ..... ??
We'll work down from 80 pounds ......
Old 06-30-2017, 03:05 AM   #87
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by radroach View Post
I guess i could take the opportunity to talk about it further.
My front tires are old and need replacing, but have been serviceable thus far through 3rd gear redlines on a backroad and cornering ok in dry weather. My struts have almost 85,000 miles on them and might need replacing soon as well.
The explanation, I was swinging wide on left hand turns probably because I was compensating for the extra weight feeling while coming through a turn. Compensating for the lack of grip I might perceive and swinging wide based on how my car responded through the corner, and not wanting to upset the front end. So MAYBE a fresh set of tires might make it all better. Maybe on my set of tires I could have turned more aggressively, at the sake of MORE body roll (don't deny this, cmon) but didn't want to upset my driving balance.
The left hand turns though was the kicker for me though. I have a banked uphill curve coming into my apartment which I enter in 2nd gear, go up and downshift to 1st to enter the lot. The car absolutely felt like a rock coming through it and the added 10-15lbs is the only explanation I have for it other than muh throttle response, which I still don't think it was.
Have you checked the tyre pressures?
Scrappydoo is offline   Reply With Quote
Old 06-30-2017, 03:07 AM   #88
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Thank goodness we use unleaded.
The Following 6 Users Say Thank You to Scrappydoo For This Useful Post:
JD001 (06-30-2017), Overdrive (06-30-2017), roddy (07-02-2017), Tcoat (06-30-2017), Ultramaroon (06-30-2017)
Old 06-30-2017, 03:14 AM   #89
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
In fact a full fuel tank helps to lower the cog, so it is not really the same. There is a reason to make the tank like this and place it very very low in the car:
But overall, yes I notice a difference in accelaration when the tank is almost empty.
The Following User Says Thank You to nikitopo For This Useful Post:
radroach (06-30-2017)
Old 06-30-2017, 03:34 AM   #90
radroach
Drives: car
They were 34.5-35 psi today.
The Following User Says Thank You to radroach For This Useful Post:
Scrappydoo (06-30-2017)
Old 06-30-2017, 03:37 AM   #91
radroach
Drives: car
@nikitopo I can definitely tell the difference between a full tank, half tank, and quarter tank too. Mostly just a difference in the sound, much louder on an empty tank than on a full tank. But the weight is definitely felt going around the corners I've mentioned previously.
new2subaru (06-30-2017)
Old 06-30-2017, 06:11 AM   #92
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Sure but this gives a very high c.o.g. when the car is on its roof.
RFB (06-30-2017)
Old 06-30-2017, 07:58 AM   #93
new2subaru
Weight Weenie
Drives: 15 FR-S
I lost the junk in the trunk a while back. 40lbs +/-
The car feels much more planted with a full tank to me.
Old 06-30-2017, 10:18 AM   #94
RFB
RFB's Avatar
Drives: FRS
A veteran M/C rider would notice the difference at half a tank !
RFB is offline   Reply With Quote
Old 06-30-2017, 10:47 AM   #95
STV3
Señor Member
STV3's Avatar
I put too much sealant in my front tire on my downhill bike last week, and every time I hit a jump I would go flying over the bars due to the increased weight from the extra sealant...
STV3 is offline   Reply With Quote
The Following User Says Thank You to STV3 For This Useful Post:
Ultramaroon (07-01-2017)
Old 06-30-2017, 11:10 AM   #96
JD001
JD001's Avatar
Drives: Subaru BRZ
I think this analogy is applicable when discussing fuel in the tank, air in the tires or obese car batteries..
The Following User Says Thank You to JD001 For This Useful Post:
menikmati (06-30-2017)
Old 06-30-2017, 11:51 AM   #97
Well, OK, fair enough.
I believe that gas tanks on most cars (after the Model T Ford) (except VW and a few others) had their gas tanks placed low and in the rear .....
Old 06-30-2017, 11:53 AM   #98
Yaaaaa......... ol Scrappydoo makes two rational posts in a row ........
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Lowering Springs Making Handling Worse? Jeff01234567 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 07-31-2014 02:21 PM
Aftermarket suspension making handling worse? RaceR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 07-24-2014 10:39 AM
