Old 06-28-2017, 02:53 PM   #1
radroach
Drives: car
New battery, worse handling
So, stock battery wouldn't crank today, got a jump and ran to autozone and put in a Duralast Platinum 35-AGM and now the car's handling is terrible! Left turns are wide and right turns sink like a stone. I think it was a 13lb increase in weight and I can definitely feel it.
What do I do now. I just dropped a lot of money on this battery. What battery should I have gone with??
update: I swapped it for a 26R-DL at autozone. It weighs about 28lbs.
Old 06-28-2017, 02:56 PM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I cannot imagine that your handling got terrible just with a battery swap. How much heavier is the new one? The stock one is around 26lbs.
Old 06-28-2017, 02:59 PM   #3
radroach
Drives: car
This one might be about 40 lbs.
Yes it made a huge difference. It sucks.
What battery should I have bought?????!!!!1
Old 06-28-2017, 03:01 PM   #4
Something is wonky. I feel zero difference in a turn with a 200 pound passenger so a slightly heavier battery isn't going to do that to you.
Try disconnecting and reconnecting it. Maybe something messed up with the electric steering (doesn't make sense but worth a shot).
Edit: Disconnecting the battery not the steering.
Old 06-28-2017, 03:02 PM   #5
Chronology
Drives: 13' Satin White Pearl BRZ
If that was the case then moving to the 16lbs battery (Braille?) Would do the opposite effect right?
Sure you didn't bump into anything and throw your alignment off?
Sounds strange, but this is also the lightest platform I have been in, so it might.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 06-28-2017, 03:14 PM   #6
STV3
Señor Member
STV3's Avatar
STV3 is offline   Reply With Quote
Old 06-28-2017, 03:15 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Sounds like the poles have been reversed, the symptoms are obvious. Going round left hand corners it is repelling whilst right hand it attracts. It has been magnetised, I suggest you rub the roof a few times then touch a balloon. I suggest you invest in a decent rubber strap that you dangle from your rear diffuser.
Old 06-28-2017, 03:16 PM   #8
Shady195
Drives: '13 10 Series FRS #1203
I will almost guarenfuckingtee that short of adding or subtracting hundreds of pounds from the car, there is just about 0 chance that you would feel the difference of 20-30 lbs on the street or track.
If that were the case you'd complain every time you put a full tank in.
Something else is up.
Shady195 is offline   Reply With Quote
Old 06-28-2017, 03:16 PM   #9
housecat
Computer Scientist
housecat's Avatar
Drives: 2014 BRZ Limited
Eat a bunch of junk food and become 13lbs fatter to balance out the added weight of the battery
Keep calm and drive safe
housecat is offline   Reply With Quote
Old 06-28-2017, 03:16 PM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Originally Posted by humfrz
I'm old and lazy
Old 06-28-2017, 03:53 PM   #11
Originally Posted by STV3 View Post
Old 06-28-2017, 03:54 PM   #12
Shady195
It's been 3 years, and everytime I read one of your posts or see your name, i imagine that you are in fact rob flanders himself.
Old 06-28-2017, 03:58 PM   #13
Rob?
Gave one of the guys from here a tour of the plant a while back. The first words out of his mouth when he got out of his car were "You really DO look like Flanders".
Old 06-28-2017, 04:02 PM   #14
Shady195
Rob?
Funny story, one of the administrators at a customer of mines name is Rob Flanders.
Ned Flanders*
Amazing. Do you sound like him to? haha
Engine Won't Crank - Battery or Worse - Sanity Check StrangeLove4791 Issues | Warranty | Recalls / TSB 16 02-22-2017 11:18 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 12:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
Lowering Springs Making Handling Worse? Jeff01234567 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 75 07-31-2014 02:21 PM
Aftermarket suspension making handling worse? RaceR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 82 07-24-2014 10:39 AM
