Old 11-22-2015, 11:00 PM   #1
jermyzy
Drives: 2013 WRB BRZ Sport-Tech 6MT
Help! Battery died, charged battery now getting all sorts of error codes!
So my battery died today, so I put on an automatic charger for a couple hours. Told me fully charge so I disconnected the charger. When I start my car, I'm getting all sorts of error codes?
Do I just need to reset something? Or did I screw something up?
jermyzy is offline   Reply With Quote
Old 11-22-2015, 11:55 PM   #2
steve99
If you have obd scanner reset codes with that.
Else remove barry negitive terminal, press brake to bleed off any residual power, reconnect battery terminal.of ok your good if your srill getting codes its likely battry is still suspect check volts and read codes.
Old 11-23-2015, 12:29 AM   #3
jermyzy
So unfortunately I can't find a socket that fits the bolt holding the negative cable....but I did pull the ecu fuse and the codes are still showing? So I'm guessing time to see the dealer...fck...
Old 11-23-2015, 12:45 AM   #4
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
My battery died 15 month after I bought the car. I got it replaced under warranty.
Vampyre is offline   Reply With Quote
Old 11-23-2015, 12:47 AM   #5
humfrz
DANG.......jermyzy ....... borrow a wrench .....
Then, I suggest you do what @steve99 suggests.
Also, you may wish to check the voltage this way (borrow a voltmeter):
http://www.aa1car.com/library/battery_runs_down.htm
While you're messen with it, you may wish to clean the battery terminals.
If the battery still acts up, I suggest you have it "load tested" at a shop.
As you know, this is not a good time of year to have a weak battery ..... especially in Canada.......
humfrz
Old 11-23-2015, 12:51 AM   #6
humfrz
That was most likely caused by a bad throw out bearing ........
humfrz
Old 11-23-2015, 12:53 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Have you guys been checking the fluid level in the cells? The OEM unit is a conventional battery requiring periodic maintenance. It WILL boil off.
Technically, outgas as molecular hydrogen and oxygen through electrolysis but, meh...
potayto-potahto
Old 11-23-2015, 12:55 AM   #8
jermyzy
So you guys are saying all the warning lights are battery related?
Old 11-23-2015, 12:58 AM   #9
Ultramaroon
not playing cards
No. I'm saying take care of your battery and it will live a long healthy life. Neglect it and it probably won't last much longer than 15 months.
...give or take.
Old 11-23-2015, 01:05 AM   #10
humfrz
Not all of them are "directly" related ....... but a bunch of them can get confused, if the battery gets weak or goes dead.
By disconnecting the battery, it gives the system a chance to "right" itself.
Codes can be "erased" by most code readers, although they may come back, unless the root cause is fixed.
Inexpensive code readers can be purchased at most auto shops ..... a code reader is a good tool to have.
humfrz
Old 11-23-2015, 01:12 AM   #11
humfrz
potayto-potahto
In addition, without going "all chemist", if you add water to the battery, use ONLY distilled water.
Why? Ask ol @Ultramaroon ..... he will give you the answer at the molecular level ......
humfrz
Old 11-23-2015, 01:13 AM   #12
jermyzy
Trying to see if any of my family has a 10mm wrench...it's 11pm here
Old 11-25-2015, 12:35 PM   #13
jermyzy
Update, took it to the dealer and yes, all the codes were being thrown because of weak battery. Switched out for a 600cca battery, hopefully I will be able to start my car in the winter reliably now, lol. Also apparently I installed two of my winter tires backwards, oops!
Keeping a battery powered device charged B-R-Z Electronics | Audio | NAV | Infotainment 1 12-15-2014 10:37 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 08:26 AM
BRZ Battery died, when I tried starting it it made a terrible noise. cmspooner Engine, Exhaust, Transmission 95 06-17-2014 11:08 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
