Old 05-19-2017, 06:03 PM   #43
Originally Posted by Detroiter View Post
I could have sworn I read it was a fuel cut limiter and that it was potentially dangerous because of that(causing lean issues and such) but I'll admit I could be wrong.
But it is definitely not a magical device that will stop that from happening. All I was trying to say was that I have seen tires give way from a over rev mis shift before. I agree that in with the engine trying to go well above the rev limit it would most likely blow the engine.
You are 100% correct on the rev limiter cutting fuel and preventing over rev in a acceleration situation. It just won't let you go that far. In a down shift your engine is fighting all that rotating mass and the energy is going to go someplace. Some will go to the wheels as they lock up and slide but even more will go to the engine since it becomes the weakest link at that point.
Old 05-19-2017, 10:18 PM   #44
stevesnj
stevesnj's Avatar
All the torque must hit the engine in that situation.
My 2016 Build thread
Old 05-19-2017, 10:30 PM   #45
Not all just enough. It isn't just the high revs that are the issue it is the suddenness of the impact. An engine is designed to build RPMs more or less linearly. When they surge with a serious over rev they go well beyond the design specs.
I am not sure how this is even a debated subject. It is basic physics and engineering.
bababooey (05-22-2017), stevesnj (05-19-2017)
Old 05-19-2017, 10:40 PM   #46
Painful read. Literally wincing over here.
Old 05-19-2017, 10:46 PM   #47
No kidding. Half these guys are going to blow the welds on their manifolds if they think they are protected from over rev.
Old 05-19-2017, 11:36 PM   #48
Over rev limiter will save us all.
Old 05-19-2017, 11:44 PM   #49
Or they can just overnight parts from Japan.
Old 05-19-2017, 11:57 PM   #50
Nobody likes the tuna here.
Old 05-20-2017, 12:00 AM   #51
They can't over rev if they don't granny shift and double clutch like they are supposed too.
weederr33 (05-21-2017)
Old 05-20-2017, 12:09 AM   #52
must!
resist!
Tcoat (05-20-2017)
Old 05-20-2017, 12:20 AM   #53
must!
resist
Old 05-20-2017, 12:27 AM   #54
Tcoat (05-20-2017)
Old 05-20-2017, 12:38 AM   #55
Ultramaroon (05-20-2017)
Old 05-20-2017, 01:41 AM   #56
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
So this guy was nuts and un-professional and he was just risking the health of the motor for a single lap time:
By the way, since young guys are reading here ... I am not saying that anyone should do this!! This was done by a very skilled racing driver , with years of experience and it was done in a closed track. In fact this guy is now the leading principal of Toyota's Racing team.
The Following User Says Thank You to nikitopo For This Useful Post:
Detroiter (05-20-2017)
Daily Driving/Spirited Driving Brakes VABeachBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-12-2017 04:11 PM
HID Headlight turns off during spirited driving tinma Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2015 10:23 AM
Brake upgrade for a DD, spirited driving. justinsstang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-23-2015 02:17 PM
Coil Overs for DD/ Spirited driving Wilso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-11-2014 01:10 PM
Spirited 86 driving in Korea ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-22-2012 02:47 AM
