Old 05-11-2017, 09:47 AM   #1
VABeachBRZ
Daily Driving/Spirited Driving Brakes
What do you suggest for spirited driving, daily with a few a few AutoX days? I was looking at.
Stoptech Front/Rear Slotted Rotors
Stoptech Front/Rear Brake Pad Set
Stainless Line Kit Front/Rear
What would you keep or change?
VABeachBRZ is offline   Reply With Quote
Old 05-11-2017, 10:13 AM   #2
StraightOuttaCanadaEh
Wes
I'm also not terribly happy with the OE brake setup, even for daily driving.
Old 05-11-2017, 10:16 AM   #3
dattran86
Driver
Drives: 2013 Whiteout FRS
I would go for Stop tech line and ditched the stop tech street performance pads because they tend to fade faster, and stock rotor are perfectly capable.
personally I would go for Ferodo DS2500 as a hybrid street/autox/track pads
You save more money with just pads/fluid and line and probably out perform stop tech slotted rotor and their street performance pads
dattran86 is offline   Reply With Quote
Old 05-11-2017, 10:26 AM   #4
JoeC
Drives: Subaru BRZ Limited
I'm curious what don't you like about the brakes? particularly why they aren't good enough for daily driving. I track my car and while I've upgraded the pads, I can't imagine what could be lacking on the street.
JoeC is offline   Reply With Quote
The Following User Says Thank You to JoeC For This Useful Post:
Pat (05-11-2017)
Old 05-11-2017, 10:34 AM   #5
Gforce
Drives: 2013 Subaru BRZ
The stock brakes are just fine. No street pads can stand up to more than a couple of hot laps before overheating. Just swap pads for any track session. Probably you can get away with just swapping front pads for something a bit harder. Rear brakes don't overheat.
2017 BRZ have a nice Brembo option which could improve the look of the brakes. I don't think it fits under the old style stock wheels. The new car with these brakes has redesigned 17 in wheels half an inch wider. The new brakes are a tight fit with the new style wheels.
The problem will still be with the street pads.
Gforce is offline   Reply With Quote
Old 05-11-2017, 10:43 AM   #6
wparsons
wparsons's Avatar
What about them are you not happy with? Feel?? stopping power??
Ferodo DS2500's, or Project mU HC800+'s are great street/autox pads, and will do great for beginners at track days as well.
I wouldn't bother with the lines, they have no performance benefit and need to be watched closer than the stock rubber lines. They do slightly improve pedal feel, but if you're not comfortable checking on them yearly, just leave the lines alone.
100% agreed on keeping the stock rotors, they work just fine. Slotted rotors aren't going to help with fade or braking power, and most modern pads don't offgas at all.
100% agreed. Good track pads and fluid are all you really need on the brakes. A BBK can help make consumables cheaper, but at stockish power levels these cars don't need more braking power at all. If you can engage ABS at speed, then tires are the weak link in stopping faster.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Icecreamtruk (05-11-2017)
Old 05-11-2017, 10:52 AM   #7
OND
OND's Avatar
Drives: 2023 BRZ
@wparsons said it all. I'd only like to add:
For brake pads, how much noise can you tolerate in daily driving? I don't think autoX is too hard on brakes anyway, so a mild upgrade might fit your needs.
I started out with Project Mu HC+ (which I think is more than enough for autoX), which got a little noisy while daily driving, so I thought "screw it, if it's going to be noisy, I might as well go all out and get Carbotech XP10s". Well, they are a delight on track but can have ear piercingly loud squeals after a week of daily driving.
OND is offline   Reply With Quote
Old 05-11-2017, 11:02 AM   #8
VABeachBRZ
Thanks for the information!
I just recently had my break start squeaking and when I looked at them, they are shot. 32k miles on the stock set. Not to shabby.
Old 05-11-2017, 11:12 AM   #9
Wes
I think both feel (which can be solved with MCB I hear) and stopping power. I like the brakes in other cars more. My gf's Cooper has massive rotors and that thing stops on a dime. I've also driven several other friends' and family cars and liked the brakes a lot. Don't know why that is, to be honest. I guess I just like to stop quicker lol.
Old 05-11-2017, 01:11 PM   #10
strat61caster
strat61caster's Avatar
+1 skip the rotors and lines
Stoptech pads should be a good DD OE replacement pad, if you didn't have problems with the OE pads while autocrossing there is no need to go more aggressive, expensive, and less DD-able. Ferodo and Project Mu hybrid pads (DS2500 and HC800+) have a reputation for being higher dust and more noise than more street oriented pads.
Get some fresh fluid in there too, ATE Typ 200 is $20/L and a bit nicer than stock. That might be the biggest factor to improving brake feel, fresh fluid. At the end of the day, the 86 brakes may just be too boosted and progressive for you, grippier pads may help you find the feel you're looking for, Stoptech may not be the answer then.
ineedyourdiddly
Old 05-11-2017, 01:43 PM   #11
JoeC
I've never done autocross but can I can't imagine the factory brake system could actually get pushed beyond its functional limit in less than 60 seconds in a parking lot.
I guess I would want to know what problem I was trying to solve before throwing a bunch of money at the car.
wparsons (05-11-2017)
Old 05-11-2017, 02:12 PM   #12
strat61caster
I've felt fade on street pads autocrossing (doubly so if it's a FWD car with an "e-diff"), most autox's are on airstrips these days, and competitive rubber is very sticky, it's much faster and harder on equipment than you give it credit for.
http://www.ft86club.com/forums/showp...&postcount=109
ineedyourdiddly
Old 05-11-2017, 02:41 PM   #13
bfrank1972
Drives: 2013 FR-S Argento
You hit the nail on the head there - many people complaining about their stock brakes need to swap out their brake fluid. My brakes are getting a little mushy as well and this is one of my projects slated over the next week or two.
bfrank1972 is offline   Reply With Quote
The Following User Says Thank You to bfrank1972 For This Useful Post:
Lynxis (05-12-2017)
Old 05-11-2017, 04:46 PM   #14
JoeC
it's much faster and harder on equipment than you give it credit for.[/url]
That's totally fair. I probably should try it out.
strat61caster (05-11-2017)
HID Headlight turns off during spirited driving tinma Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2015 11:23 AM
Brake upgrade for a DD, spirited driving. justinsstang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-23-2015 03:17 PM
Weight Reduction (budget diet) for daily/spirited driving 1086 Scion FR-S / Toyota 86 GT86 General Forum 86 03-22-2015 02:18 PM
Coil Overs for DD/ Spirited driving Wilso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-11-2014 02:10 PM
Spirited 86 driving in Korea ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-22-2012 03:47 AM
