Old 09-02-2015, 08:44 AM   #1
tinma
Drives: '13 BRZ
HID Headlight turns off during spirited driving
tinma is offline   Reply With Quote
Old 09-02-2015, 09:14 AM   #2
frslee
Just drive it
Drives: 13' FR-S
Try swapping bulbs left to right and see if it happens on the driver side, or try switching to oem bulb. It could be a faulty bulb and I'd contact the seller.
frslee is offline   Reply With Quote
Old 09-02-2015, 10:49 AM   #3
smudge
Drives: Supercharged GT86
If you've swapped the bulbs already then I'd bet it was something to do with that
smudge is offline   Reply With Quote
Old 09-02-2015, 03:11 PM   #4
tinma
Drives: '13 BRZ
Old 09-02-2015, 03:55 PM   #5
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Check connections between bulbs and ballast. Also swap the driver side bulb to the passenger side and drive how you were before. If there is no problem then its your bulb. if there is a problem then definitely you ballast.
Old 09-07-2015, 08:05 PM   #6
tinma
Drives: '13 BRZ
I may have found the problem... The connector at the bulb from the ballast is burnt/melted. Let's see if Subaru will fix this under warranty
Old 09-09-2015, 07:11 PM   #7
johnbradshow
Drives: Audi
I think you get a bad aftermarket HID bulb or the moisture leaks and cause the burn.
johnbradshow is offline   Reply With Quote
Old 09-09-2015, 08:17 PM   #8
ryoma
ryoma's Avatar
the dealership will probably say that you didn't use a genuine OEM product and went aftermarket, which caused the failure then deny your warranty claim. or they might not care and fix it for you. 50/50
Old 09-09-2015, 11:56 PM   #9
tinma
Drives: '13 BRZ
Old 09-10-2015, 12:49 AM   #10
Poodles
Drives: 2015 Series.Blue
This is why you don't use cheap HID bulbs...
Old 09-10-2015, 08:26 AM   #11
tinma
Drives: '13 BRZ
Old 09-10-2015, 10:39 AM   #12
Diode Dynamics
Diode Dynamics's Avatar
Just because we price our products fairly doesn't mean they are "cheap" or low-quality.
They are produced by CNLighting who also manufactures "Morimoto's" XB HID bulb replacements.
OP, it honestly sounds like they aren't seated properly, but please give us a call: (314) 205-3033
We will help you troubleshoot this issue, and provide warranty replacements if needed
We appreciate your support and we want to make sure you are taken care of
Thanks,
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
tinma (09-10-2015)
Old 09-10-2015, 10:46 AM   #13
tinma
Drives: '13 BRZ
Thanks,
Nick C.
I will be giving you guys a call after I get my connector fixed as it is melted and Im going to see if Subaru will replace them. Thanks for the quick response!
The Following User Says Thank You to tinma For This Useful Post:
Diode Dynamics (09-14-2015)
Old 09-10-2015, 11:06 AM   #14
D_Thissen
D_Thissen's Avatar
Talk to Glenn at Marostica, and play dumb
The Following User Says Thank You to D_Thissen For This Useful Post:
tinma (09-10-2015)
Navi radio randomly turns off while driving Streetthrowback Issues | Warranty | Recalls / TSB 12 01-10-2016 07:40 PM
Weight Reduction (budget diet) for daily/spirited driving 1086 Scion FR-S / Toyota 86 GT86 General Forum 86 03-22-2015 01:18 PM
Coil Overs for DD/ Spirited driving Wilso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-11-2014 01:10 PM
Lowering as a daily & sometimes spirited driver 1086 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 38 12-24-2013 10:26 PM
Spirited 86 driving in Korea ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-22-2012 02:47 AM
