Old 05-19-2017, 02:07 AM   #1
Pepper86
Drives: 2017-86
Spirited driving fail? Over rev?
I was trying to exit the freeway with "authority" and go from 6th to 4th at 70~ish. When I did so: to my surprise; it felt like I hit the brakes glanced down and saw 7k+ rpm I think it was around 7100-7200rpm but I for sure hit the rev limiter as it felt like I hit the brakes, and the engine cut out. I am sure I clutched as it is an instinct. Granted all of these event happened in a matter of seconds(or less). I am an experienced driver with some track time, so I have a decent understanding of this. I swear I went to 4th, but it is impossible for the car to hit 7500rpm in forth at any where less than 100mph if I am not mistaken. So the only other option is that I went into 2nd? Which means that I over revved? I have the Toyota 86 now which has the slightly higher final drive of 4.3~ and @70mph~ in 2nd gear is around 8500-9k(rpm)? That sound about right? I am trying to figure all of this out as like I said this all happened really fast.
Pepper86 is offline   Reply With Quote
Old 05-19-2017, 02:23 AM   #2
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Thats call money shift lol.
I don't think you over rev, because our 3rd gear max speed is 83mph, 6th to 4th at 70mph is totally fine.
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
stevesnj (05-19-2017)
Old 05-19-2017, 02:26 AM   #3
swarb
Is this your first manual transmission car? How much experience do you have?
Did you more the shifter from 6th as up and then left then down, or up and then down? It would auto center and only up and down movement is needed. If you did the up,left,down movement, you probably went into 2nd.
Did you rev match/blip the throttle?
Shifter springs would help a little in the feel department.
Old 05-19-2017, 08:33 AM   #4
stevesnj
stevesnj's Avatar
I love the 6th to 4th downshift in this car, the engine loves to rev and passing is enjoyable doing the 6th to 4th downshift on the highway
My 2016 Build thread
Old 05-19-2017, 08:35 AM   #5
stevesnj
stevesnj's Avatar
Just a mis shift, the computer did it's job to cut power. Everyone hits the limiter or missis a shift. Enjoy and don't sweat it.
Old 05-19-2017, 09:24 AM   #6
celek
Resident Gear Head
celek's Avatar
If it was truly 70MPH you have nothing to worry about...
celek is offline   Reply With Quote
Old 05-19-2017, 09:39 AM   #7
TommyW
TommyW's Avatar
Drives: '13 Whiteout
You hit 2nd. That's how you over rev and ruin motors. The rev limiter doesn't help with downshifts that are missed. 5th or 6th to 2nd can happen very easily. That is the downshift that is super important to get right with this shift pattern so gotta be mindful when doing so.
The Following User Says Thank You to TommyW For This Useful Post:
ILLSMOQ (05-19-2017)
Old 05-19-2017, 10:40 AM   #8
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
The limiter does help you on downshifts. In events like this when the engine hits red line the fuel cut rev limit is so harsh that it has a great chance of locking up the rear wheels. This will stop your engine from being forced to rev higher as the wheels won't be spinning any faster than it is. I've seen it happen on many different rwd cars. Never being on that I was driving I should add
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
The Following 2 Users Say Thank You to Detroiter For This Useful Post:
stevesnj (05-19-2017), TommyW (05-19-2017)
Old 05-19-2017, 11:08 AM   #9
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have to disagree with you on this one. A long time ago when I was younger and stupid, I was racing and shifted into 2nd while trying to shift to 4th, and completely trashed an engine, pistons melted, rods broke, all kinds of shit because there was no rev limiter in the world that stopped the engine from revving to 10K+.
The Following 5 Users Say Thank You to Sportsguy83 For This Useful Post:
Detroiter (05-19-2017), reeves (05-19-2017), strat61caster (05-19-2017), Ultramaroon (05-19-2017), wparsons (05-22-2017)
Old 05-19-2017, 11:22 AM   #10
Detroiter
Detroiter's Avatar
I guess I didn't write what I meant very good What I meant was that it can help in some cases. I could imagine shifting to over rev a engine past 10k would probably cause tragic things to happen no matter if the wheels could lock up from the limiter or not.
I'm guessing the times I've seen it was when the miss shift resulted in the engine only trying to rev slightly past the limiter allowing the wheel lock up to slow the car quickly enough to get it back to the usable RPM range. Also could be that I've seen it happen most on MX5's which being extremely light could allow for the wheels to lock up easier, atleast that's what I'm thinking
Raven
Sportsguy83 (05-19-2017), stevesnj (05-19-2017)
Old 05-19-2017, 11:24 AM   #11
Sportsguy83
Drives: Limited BRZ
Yea it makes sense. I guess it depends how far away from the Rev limiter the misshift takes the engine, and I bet the lightweight MX-5 helps.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 05-19-2017, 11:39 AM   #12
JD001
JD001's Avatar
Drives: Subaru BRZ
Oh noooo, not another MT thread about changing gears...
The Following 2 Users Say Thank You to JD001 For This Useful Post:
bababooey (05-19-2017), stevesnj (05-19-2017)
Old 05-19-2017, 11:48 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm, is clutch also drive-by-wire in ours, or only accelerator? If yes, i can see ease to impement safeguard in ECU to not allow engaging it untill rpms drop to safe range even with pedal depressed.
Old 05-19-2017, 12:01 PM   #14
Detroiter
Detroiter's Avatar
No our clutch is hydralic. I'm pretty sure there is no cars using a clutch drive by wire system, or at least I've never heard of one before.
Raven
Daily Driving/Spirited Driving Brakes VABeachBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-12-2017 04:11 PM
HID Headlight turns off during spirited driving tinma Cosmetic Modification (Interior/Exterior/Lighting) 14 11-19-2015 10:23 AM
Brake upgrade for a DD, spirited driving. justinsstang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 09-23-2015 02:17 PM
Coil Overs for DD/ Spirited driving Wilso Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 06-11-2014 01:10 PM
Spirited 86 driving in Korea ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-22-2012 02:47 AM
