Old 04-29-2017, 10:49 AM   #1
solort
Drives: Series 10 FRS
Whining noise at highway speed- Cause?
I am getting a high pitch whining noise that i notice around 60mph and it gets more noticeable at higher speeds. The pitch changes at speed, and when I lift the throttle, it disappears. I suspect it may be a rear end ring and pinion that has developed a wear pattern that makes noise with torque from throttle and disappears without the torque. Seems to make noise in 5th and 6th gears. Thoughts? Anyone else get this noise?
I had an 1st gen RX7 that made similar noise that was the ring and pinion wear, so that was where my speculation came from. Thanks
solort is offline   Reply With Quote
Old 04-29-2017, 11:08 AM   #2
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
You can always start with a rear diff fluid flush and replacement. at 27k Miles when I did my AMSOIL everything, my rear diff fluid was black, black, black...
The Subaru transmission fluid looked healthly but I had 1st and 2nd gear notching issues that needed to be resolved with better fluid. That has since been resolved.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 04-30-2017, 06:59 PM   #3
toeout
I've had that noise for the past 40K miles.
Here's the thread where other owners have experienced it: http://www.ft86club.com/forums/showt...h+pitch&page=3
For the duration that I've had it, it hasn't gotten louder. To me it doesn't seem mechanical but electrical in nature. Especially how sharp the border between the noise/ no-noise occurrence is. I mean you only barely touch the gas pedal to make it appear and then it doesn't chance the tone no matter how much load you put on the engine. Same with lifting the throttle - it's a sharp transition into no-noise when the foot is almost coming off the pedal.
toeout is offline   Reply With Quote
Whining noise when pressing clutch? cupcake917 Issues | Warranty | Recalls / TSB 14 03-12-2019 02:49 PM
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 12:04 PM
Rattle noise over 65mph (100kmh) on highway only Jackal84 Issues | Warranty | Recalls / TSB 24 01-08-2014 03:45 PM
Huge noise after hitting a big bump on the highway! Help? Monstermotor BRZ First-Gen (2012+) — General Topics 10 08-20-2013 05:29 PM
Wind/road noise at highway speeds? Kieranz BRZ First-Gen (2012+) — General Topics 20 06-13-2013 11:11 AM
