Old 10-08-2012, 11:31 PM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
whining/whirring noise during high load/rpm clutch engagement
EDIT: another user below has documented this on video,
well, just a little over 5000km and i'm having my first "wtf" issue with the car
when i switch gears there is a whinning/whirring noise, almost like a failed bearing, or the sound of a drill bit overheating inside a piece of wood...
i can replicate the noise if i can drive the car at steady speed, clutch out, keep the gas at around 5000rpm and let the clutch slowly engage and SLIP IT, and can maintain the noise if i maintain the proper slip
my first reaction is a failing throwout bearing
my second thought was maybe something is getting lose and its high frequency resonance.
also, i can faintly hear the noise when i'm light on the throttle, ie, crusing, when engaged in any gear
and by faint i mean FAINT, i have a pretty good ear for these things and wouldn't be surprised if no one else would pick it up (i'm the type of guy who can hear the noise a TV makes on a "black" channel)
Old 10-08-2012, 11:40 PM   #2
ArKiTeCkT
ArKiTeCkT's Avatar
Drives: 2010 Gen Coupe, 2013 BRZ 6MT S.Tech
Are you talking about this:
http://www.ft86club.com/forums/showt...538#post459538
ArKiTeCkT is offline   Reply With Quote
Old 10-09-2012, 01:24 AM   #3
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
sounds bout right
\'muted goose" and "whooop"
if i make perfect shifts it does nothing, only when i drag the clutch
which is fine, i guess, since the latter happens rarely... but i'm curious as to why now?
Old 10-10-2012, 11:25 PM   #4
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
Is it the sound in the video below? The other thread didn't sound like they were describing what I have but your description did. I get this with just the right amount of slip.
[ame="http://www.youtube.com/watch?v=-zsPn6YMf5g&feature=plcp"]2013 FRS buzz when clutch partially engaged/slipping - YouTube[/ame]
enigmaaron is offline   Reply With Quote
Old 10-11-2012, 03:33 AM   #5
EZWood
BAMF
EZWood's Avatar
You mean like BET?
The Following 10 Users Say Thank You to EZWood For This Useful Post:
7thgear (10-11-2012), brandonblt2 (01-23-2019), Creole (03-06-2014), FRSBRZGT86FAN (12-27-2013), Ingen (11-28-2012), Jesse (03-30-2013), LeeMaster (03-29-2013), Nikuku (03-14-2013), number1Tango (01-17-2013), Subie (10-11-2012)
Old 10-11-2012, 09:30 AM   #6
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
yep, this is the exact sound.
do we have a thread on this?
Some on another forum mentioned it could be a glazed clutch.. which i refuse to believe since i'm no manual noob. My VW survived 100,000km and 5 years of autocross/track racing before giving out.
Shoulda bought a volkswagen ya.
Old 10-11-2012, 10:47 AM   #7
enigmaaron
enigmaaron's Avatar
I think this is the thread. I searched around and didn't see anything similar posted.
It sounds to me like a high pitch rattle coming from the dash area. Just the right amount of load/slip causing something in the dash to vibrate.
Old 10-11-2012, 10:49 AM   #8
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
i tried to replicate the noise with the emergency brake on, no success
Old 10-21-2012, 12:46 AM   #9
Sambosis
Drives: FR-S Asphalt MT
Honk-like sound when shifting out of gear in higher RPM's
This is something I heard occasionally but though I was just hearing things. Then I started to hear it more often and now often enough to figure out when it happens. When I accelerate fairly hard, right as I am shifting out of gear I will hear what sounds almost like a distant horn sounding... say the word toot in a semi-high pitch voice and that is what it sounds like.
It's starting to happen often enough that I'm pretty sure I could recreate it at the dealership if I drove them around the block. I was just wondering if anyone else has experienced this and if it is something I should worry about. I am 100% stock atm.
Sambosis is offline   Reply With Quote
Old 10-21-2012, 11:42 AM   #10
gmookher
new
gmookher is offline   Reply With Quote
Old 10-21-2012, 11:45 AM   #11
Spartan65
USMC Veteran Semper Fi
Spartan65's Avatar
Drives: 2010 WR Blue STi
You have the Beep set to on when the Redline pops up?
Spartan65 is offline   Reply With Quote
Old 10-21-2012, 11:52 AM   #12
MmmHamSandwich
You know you want it.
MmmHamSandwich's Avatar
Drives: '13 FR-S
Might want to check your MTF levels.
The Following User _________ Stay_Puft(09-13-2014)
Says Thank You to
MmmHamSandwich For
This Useful Post:
MmmHamSandwich is offline   Reply With Quote
Old 10-21-2012, 04:20 PM   #13
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
did you add a turbo???
Flat Black VW is offline   Reply With Quote
Old 10-23-2012, 12:30 PM   #14
ziptiespec
ziptiespec's Avatar
Drives: '01 Honda S2000
I've experienced this as well. I think I've heard it 2-3 times and it wasn't when I was shifting at high RPMs. I can't reproduce it and I haven't heard the sound in about a week.
ziptiespec is offline   Reply With Quote
Strange noise/vibration under heavy engine load Panecki17 Issues | Warranty | Recalls / TSB 65 05-04-2017 08:58 AM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 03:03 PM
Clutch noise new to-day Skye Issues | Warranty | Recalls / TSB 16 11-19-2016 12:42 PM
5k~ Miles - Clutch with extreme broken glass noise Pscylo Issues | Warranty | Recalls / TSB 11 08-30-2012 02:12 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 06:01 PM
