Old 04-22-2017, 06:44 PM   #1
John27
Drives: scion fr-s
after resetting ecu
how long does it take for ecu to relearn everything again ?
John27 is offline   Reply With Quote
Old 04-22-2017, 06:53 PM   #2
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I think it is 100 miles. I put a new battery in the FRS today and I followed these steps after connecting the battery before I actually started the car.
Turn the ignition to on, but don't start the motor
press the gas pedal all the way to the floor slowly and steadily - take about 3 seconds to get to the floor
slowly and steadily release the gas pedal back up - again, about 3 seconds
repeat the press and release for a total of 5 complete down-up cycles
turn the ignition off
When I started the car after that everything was fine no rough idle or anything. You can try disconnecting again and following those steps.
DandoX is offline   Reply With Quote
Old 04-22-2017, 07:13 PM   #3
steve99
Drives: FT86
Their is no time or distance. Ecu continuously learns fueling and timing corrections.
After a reflash/reset it needs to calibrate some initial settings with cams throttle etc.
see here http://www.ft86club.com/forums/showt...30#post1803730
The Following 4 Users Say Thank You to steve99 For This Useful Post:
DandoX (04-22-2017), humfrz (04-22-2017), stevesnj (04-22-2017), Tcoat (04-22-2017)
Resetting ECU after cleaning MAF? Hentai Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 12-15-2015 02:28 PM
Resetting the ECU after running 87 gas orangespark FR-S / BRZ vs.... 10 08-29-2015 04:23 PM
iPod Keeps resetting, hanging; etc... Anyone else seeing this Max1957 Electronics | Audio | NAV | Infotainment 5 03-17-2014 08:41 PM
Advance Mutiplier resetting on restart? feldy Software Tuning 122 11-05-2013 10:08 AM
