Drives: Honda Accord Euro
I recently testdrove MY2017 BRZ finally, and being on autobahns I can do some speed. I immediately noticed, that while the car being stable at high speeds, it was very vulnerable to (probably) any wind. The surface was smooth, so I don't think it was bad roads but rather wind, also I did not feel anything in a steering wheel (like from low-profile tires, etc).
I checked the forums and there are hints about it there and there, so I think it is worth to its own solution thread. Around 100 mph car is "jumping" left and right, while obviously I drove straight. The car was stock, dealers presentation model. I am unhappy about it, since I want from a car to be able drive at those speeds at ease and it is one of the reasons I wanted a good handling sports-car. I have never experienced vulnerability like that in any car I have driven, including estates with much more side-area. And lastly, my Accord with the same Primacy HP tires (225/50/17) is rock stable at those speeds. No feedback and soft, but stable. Do anybody know a reason for this, and more importantly, can anything be done to solve this to be at least "normal"? Thank you! Last edited by JDM4E; 04-10-2017 at 05:31 PM. |
| The Following User Says Thank You to JDM4E For This Useful Post: | F R YESS (04-09-2017) |
#2 |
Drives: '13 FRS - STX
Personally I do not believe it is wind, I had an old boxy '80s truck that was absolutely affected by wind and you could hear and feel when a gust caused the car to move. The 86 is absolutely less affected by crosswinds and large commercial vehicles due to it's low profile. There are some here that believe it is wind, I regularly drove across a bridge that routinely gets flagged with 'high wind advisory' 30+ mph gusts easily on a good day, the 86 is very easy to maintain in lane provided the alignment specs are conservative.
IMO it is wheel alignment and road related, ask for an alignment to be performed on the car, a little toe in all around will likely have it feel just like you want it to, factory alignment specs are not perfect, and maybe the dealership set alignment to be a bit more aggressive during pre-sale inspection since that's what many 86 buyers like. |
#3 |
Drives: Subaru BRZ
I think it's dependent on the following element..
#4 |
Huge E85 fan!
Drives: 2016 Scion FRS
It's a dealer's model- check underneath and make sure the panels under the car are all there. Maybe it's been in an accident and the alignment is off? I get some cross wind buffeting but not as bad as you describe, though it got worse when I installed the lip kit. It doesn't get really squirrelly until over 120 MPH.
#5 |
We drive well over 100 on the track and have never noticed that. We do use track tires and a good alignment, so I doubt it is body related.
#6 |
Drives: Subaru BRZ
I would start with the tires (uneven wear/uneven pressure) and then look at alignment and/or buckled wheels and then suspension (loose components) and then chassis for alignment..
#7 |
Thanks, so basically you are saying it is not wind and it is not normal? That would be great. BTW weird, that it is worse with the lip kit - that should decrease lift if anything.
#8 | |
If they refuse, head out to another dealer and hop in a different car. There's other things too like tire pressures and potential unseen damage, some cars had spring spacers not removed early on, things like that, but imo alignment has the biggest impact to how the car acts. |
#9 |
Drives: 2014 GT86
BTW, why not check tire pressure from steps listed by yourself at any fuel station?
#10 |
keep in mind that the stock alignment is a wide range. you will get better results if you specify a certain alignment setting. I personally use the following settings:
Front: Camber: -2 Caster: 6 degrees Total Toe: 0 Rear: Camber: -1.5 Total Toe: 1/16" total toe in
#11 | |
Drives: 2017 BRZ
The car is definitely sensitive to alignment. The other thing to consider here is that the car may simply be providing that much more feedback, so it's easy to notice those little annoyances where other cars they'd be absorbed by all the little things that make the car feel mushy... |
| The Following User Says Thank You to cjd For This Useful Post: | strat61caster (04-10-2017) |
#12 |
Drives: 2014 scion frs
I have felt this too OP. Windy day, strong gusts hitting the rear quarter make the back end of the car feel uncomfortably light at 100 mph. (Deserted highway, I had just been passed by an Audi A4 and sped up from limit just to see how fast he was cruising.) After a few seconds of "Whoa, this is new!" I dropped back to 60 and the car went stable again. Alignment is good, tires were almost new, pressures good. I do have the stock rear spoiler.
I think it is more to do with the shape of our cars. Not saying they produce gobbs of down force or anything but I remember a video on the development of the car where the Japanese engineers were talking about the shape and how every crease has a purpose aerodynamically. Even the little canards on the tail lights are there to do something. A strong, gusty wind on the rear quarter definitely does lighten the tail end and push the car around a little at those kind of speeds, IMO. If I hadn't experienced it, I would have been skeptical. |
| The Following User Says Thank You to 7 skulls For This Useful Post: | JDM4E (04-10-2017) |
#13 |
I am in the same boat as the OP and have been baffled ever since I joined the forums that no one really compains about this.
When I first purchased the car I was extremely concerned about the squirly feeling this car has on the freeway. I bought 2 different sets of tires and got it aligned probably 4 times, had the dealer check everything probably 3 times and never found a solution.......until summer time. I purchased my car during our windy season. When Summer came along and the wind went away it was like a completely different car. It is now windy season again and it drives me nuts! I feel like it is a combo of the VSC, electric power steering and the electronic brake distribution trying to over compensate at times. I am convinced that these systems are still ACTIVE AND VARIABLE at all times even when the dash lights aren't indicating it(unless in peddle dance mode). |
| The Following User Says Thank You to Mr Nerd For This Useful Post: | JDM4E (04-10-2017) |
#14 | |
| Stability Control intervention at very low speed | smbstyle | Issues | Warranty | Recalls / TSB | 10 | 07-15-2016 02:11 PM |
| High winds + large water tank = | Manji | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 10-06-2015 12:33 AM |
| High RPM for current speed | HachiRo | Engine, Exhaust, Transmission | 14 | 04-02-2015 02:59 PM |
| Light weight and high winds in a Subaru | alluringreality | BRZ First-Gen (2012+) — General Topics | 49 | 03-01-2014 06:04 PM |
| Video: BRZ / FR-S High Speed Run to 124 MPH (200 km/h) | Levi | BRZ Photos, Videos, Wallpapers, Gallery Forum | 43 | 05-16-2012 12:37 AM |
